Bug [Problem assumed resolved - no response from user] Problem component JotCache with Kunena 1.7.1
I just tested this component which is wonderful but I have a problem, and that is not how to make work properly with kunena me.
Every time you answer any kunena post, I get this error
Warning: call_user_func_array () [Function.call-user-func-array]: First argument is expected to be a valid callback, 'JCache: _getFilePath' was Given in / home / josporta / public_html / libraries / joomla / cache / controller . php on line 67
And the answer looks good, in fact it goes the answer if it does not refresh in the browser.
As I can make it work correctly this component?
I tell you, it is great, page loads very very fast, but I have that problem.
Any solution?
regards
There is no Kunena 1.7.3.
Unless the problem of joomla.
The problem is with jotcache 1.71 kunena
I've tried kunena Jotcache and load much faster and gave me much more developers.google.com/pagespeed/ score, the problem is that the answer was a failure, the mistakes that I discuss in the first message, and if refresh the page went out he had responded.
You can not fix this?
Would be great to kunena and anyone with joomla.
Thank you.
I will ask you again: please read posting guide printed above. I have no clue why you have this issue but, if your problems are resolved by removing JotCache then I suggest you talk to the developer of that extension. Are your problems resolved by removing JotCache?
Contact JotCache developer -- to me it looks like the bug is in there.
thanks to two;)
We have not seen your configuration report. It is our opinion that this is not a support issue for Kunena but, instead, is a support issue for the developer of JotCache. I do not think there is anything more that we can say about this issue at this time.
I've tried JotCache (on J! 1.5) and it seems to "work"; I don't like it and I've uninstalled it. Other people are welcome to try this component for themselves. The Kunena project has not tested this component and will probably not test the component as matter of support, either now or for the foreseeable future.
