Question Attachment Security Problem
15 years 2 months ago #106078 by rgblogs
Hello
I run a private forum that is visible only after logging in. I am using Kunena 1.7 version on joomla 1.5.23
All attachments are uploaded in sitename.com/media/kunena/attachments/...
However, the folder is accessible to all via web browser. Also files can be downloaded by anyone who know the link of the file.
Plz help me how to fix this...
I have no signature :)
15 years 2 months ago #106081 by xillibit
This is the normal behaviour of Kunena, if you don't know the name of files you can't find it. Actually, i don't know a way to prevent that.
15 years 2 months ago #106091 by fxstein
rgblogs wrote: Hello
That is correct and as designed behavior NOT a security problem. The same is true for all other Joomla files on your server. If you know the link to any image or uploaded file within Joomla you can access or download it.
IF you want to protect certain files from certain user groups you will have to look at other download manager solution within the Joomla extension directory.
Hope this helps!
15 years 2 months ago #106102 by rgblogs
thanks for the reply
yes, download managers use redirect feature to protect files from being downloadable to guest according to acceess level.
I hope kunena can also add that feature in future.
15 years 2 months ago #106347 by Matias
Yes, it's something we have thought of implementing, but until we get more requests on it, other things have higher priority. So please go our front page and click on the right side to add your feature request. And remember to vote on it!
15 years 1 week ago #110950 by yoonique[.net]
I also believe this is a security issue. The whole content of a topic should be protected including attachments (if the topic is set for registered users only).
You probably haven't received a lot of requests for this, because pretty much all users assume that atttachments are protected as well. I only discovered this by accident :-)
For example Zoo uses the following code to protect downloads ("hide path behind md5 hashed URLs).
public function download($check = '') { // init vars $filepath = JPATH_ROOT . '/' .$this->_data->get('file'); $download_mode = $this->_config->get('download_mode'); // check limit if ($this->isDownloadLimitReached()) { header('Content-Type: text/html'); echo JText::_('Download limit reached!'); return; } // trigger on download event $this->app->event->dispatcher->notify($this->app->event->create($this, 'element:download', compact('check'))); // output file if ($download_mode == 1 && is_readable($filepath) && is_file($filepath)) { $this->_data->set('hits', $this->_data->get('hits', 0) + 1); $this->app->filesystem->output($filepath); } else if ($download_mode == 2 && $this->filecheck() == $check && is_readable($filepath) && is_file($filepath)) { $this->_data->set('hits', $this->_data->get('hits', 0) + 1); $this->app->filesystem->output($filepath); } else { header('Content-Type: text/html'); echo JText::_('Invalid file!'); } // save item $this->app->table->item->save($this->getItem()); } public function output($file) { @error_reporting(E_ERROR); $name = basename($file); $type = $this->getContentType($name); $size = @filesize($file); $mod = date('r', filemtime($file)); while (@ob_end_clean()); // required for IE, otherwise Content-disposition is ignored if (ini_get('zlib.output_compression')) { ini_set('zlib.output_compression', 'Off'); } // set header header("Pragma: public"); header("Cache-Control: must-revalidate, post-check=0, pre-check=0"); header("Expires: 0"); header("Content-Transfer-Encoding: binary"); header('Content-Type: '.$type); header('Content-Disposition: attachment;' .' filename="'.$name.'";' .' modification-date="'.$mod.'";' .' size='.$size.';'); header("Content-Length: ".$size); // set_time_limit doesn't work in safe mode if (!ini_get('safe_mode')) { @set_time_limit(0); } // output file $handle = fopen($file, 'rb'); fpassthru($handle); fclose($handle); } public function filecheck() { $secret = $this->_config->get('secret'); return md5($this->_data->get('file').$secret.date('Y-m-d')); }
