This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Kunena menu size problem
15 years 9 months ago #85014 by Foxtrot
I have just turned on the kunena menu module and checked out the newly installed forum. The size of the menu buttons seems too small and the text overlapping across the edges. Is there anything specific that I need to do to make the buttons bigger just like in this www.kunena.org forum?
Cheers
15 years 9 months ago #85126 by kureis
Replied by kureis on topic Re: Kunena menu size problem
I have changed the padding in kunena.forum.css as follows:
#Kunena #ktab a {
margin: 0;
padding: 0 5px 0 5px;
it's around line #508
15 years 9 months ago #85133 by Foxtrot
Thanks for trying, but that didn't help. I would like the buttons to be black and spaced just like the ones in this www.kunena.org forum.
15 years 9 months ago #85863 by Foxtrot
Anyone have a solution?
15 years 9 months ago #85867 by sozzled
We might be able to help you better if we knew where to look. What is the URL of your website?
15 years 9 months ago #85891 by Foxtrot
