Question [SOLVED] Suddenly problems...
15 years 5 months ago #71006 by cowboysdude
Huge Thanks as always!!! Yes I went back to Purity ii and the megamenu is the ONLY thing not working and to be honest I can live with that! I simply switched to moomenu and it looks good and performs well!
I thank you again for your help and suggestions and I WILL be reading more in the discussion that you have pointed me to!
See... all is not lost folks... but sometimes you have to the smart thing and make changes. It does work if you give it half a chance.
B)
15 years 5 months ago #74913 by Kymmy
Replied by Kymmy on topic Re: Suddenly problems...
I was desperate to find the solution to Megamenu and mootools and eventually found an updated script online.. So here's the solution (posted on JA as well)
Yahoo!!! Found it. You still need to change the DRAG.BASE.EXTEND to DRAG.EXTEND in ja.ddmod.js (line 451) and also there's a change (it's relevant to kyanite2 but no idea about other templates) to be done on line 197 of Mega.css (change 50px to 0) but here's the mega.js (you will need to activate mootools 1.2 upgrade so unfortunately if you have any other 1.2 problems this will cause issues)
Tested on Firefox 3.6.12 and IE9 (normal and compat modes)
var jaMegaMenuMoo = new Class({ options: { slide: true, //enable slide duration: 300, //slide speed. lower for slower, bigger for faster transition: Fx.Transitions.Sine.easeOut, fading: false, //Enable fading bgopacity: 0.9, //set the transparent background. 0 to disable, 0<bgopacity<1: the opacity of the background delayHide: 500, position: 'bottom', //position of toolbar. rtl: 0, //right to left mode direction: 'down', action: 'mouseenter', //mouseenter or click tips: true, //enable jatooltips hidestyle: 'fastwhenshow', //events onItemShow: null, //function (li) {} onItemHide: null, //function (li) {} onItemShowComplete: null, //function (li) {} onItemHideComplete: null, //function (li) {} onFirstShow: null, //First child show onLastHide: null, //All child hidden onLoad: null //Load done }, initialize: function(menu, options){ this.setOptions(options); this.menu = menu; this.childopen = new Array(); this.items = null; this.imageloaded = false; //window.addEvent('load', this.start.bind(this)); this.start(); }, startedcheck: function () { this.imageloaded = true; if (!this.items) this.start(); }, start: function () { this.menu = $(this.menu); //preload images var images = this.menu.getElements ('img'); if (images && images.length && !this.imageloaded) { var imgs = []; images.each (function (image) {imgs.push(image.src)}); if (imgs.length) { new Asset.images(imgs, { onComplete: function(){ this.imageloaded = true; this.start(); }.bind(this) }); this.starttimeout = setTimeout (this.startedcheck.bind(this), 3000); //check if start after 10 seconds. If not, call start manual return ; } } clearTimeout (this.starttimeout); if (this.items) return; //started already this.items = this.menu.getElements ('li.mega'); //this.items.setStyle ('position', 'relative'); this.items.each (function(li) { //link item if ((a = li.getElement('a.mega')) && this.isChild (a, li)) li.a = a; else li.a = null; //parent li._parent = this.getParent (li); //child content if ((childcontent = li.getElement('.childcontent')) && this.isChild (childcontent, li)) { li.childcontent = childcontent; li.childcontent_inner = li.childcontent.getElement ('.childcontent-inner-wrap'); var coor = li.getElement('.childcontent-inner').getCoordinates (); li._w = coor.width; li._h = coor.height; li._ml = li.childcontent.getStyle('margin-left').toInt(); li._mt = li.childcontent.getStyle('margin-top').toInt(); li.level0 = li.getParent().hasClass('level0'); // //li.childcontent.setStyles ({'width':li._w+50, 'height':li._h}); if (li._w) { li.childcontent.setStyles ({'width':li._w}); li.childcontent_inner.setStyles ({'width':li._w}); } //fix for overflow li.childcontent_inner1 = li.childcontent.getElement ('.childcontent-inner'); li.childcontent_inner1.ol = false; //Fix for IE: correct render at the first show li.childcontent_inner1.setStyle ('min-height', li.childcontent_inner1.offsetHeight); if (li.childcontent_inner1.getStyle ('overflow') == 'auto' || li.childcontent_inner1.getStyle ('overflow') == 'scroll') { li.childcontent_inner1.ol = true; //fix for ie6/7 if (window.ie6 || window.ie7) { //li.childcontent_inner1.setStyle ('position', 'relative'); } if (window.ie6) { li.childcontent_inner1.setStyle ('height', li.childcontent_inner1.getStyle ('max-height') || 400); } } //show direction if (this.options.direction == 'up') { if (li.level0) { //li.childcontent.setStyle ('top', -li.childcontent.offsetHeight); //ajust top position li.childcontent.setStyle ('bottom', li.offsetHeight); } else { li.childcontent.setStyle ('bottom', 0); } } } else li.childcontent = null; if (li.childcontent && this.options.bgopacity) { //Make transparent background var bg = new Element ('div', {'class':'childcontent-bg'}); bg.injectTop (li.childcontent_inner); bg.setStyles ({'width':'100%', 'height':li._h, 'opacity':this.options.bgopacity, 'position': 'absolute', 'top': 0, 'left': 0, 'z-index': 1 }); if (li.childcontent.getStyle('background')) bg.setStyle ('background', li.childcontent.getStyle('background')); if (li.childcontent.getStyle('background-image')) bg.setStyle ('background-image', li.childcontent.getStyle('background-image')); if (li.childcontent.getStyle('background-repeat')) bg.setStyle ('background-repeat', li.childcontent.getStyle('background-repeat')); if (li.childcontent.getStyle('background-color')) bg.setStyle ('background-color', li.childcontent.getStyle('background-color')); li.childcontent.setStyle ('background', 'none'); li.childcontent_inner.setStyles ({'position':'relative', 'z-index': 2}); } if (li.childcontent && (this.options.slide || this.options.fading)) { //li.childcontent.setStyles ({'width': li._w}); li.childcontent.setStyles ({'left':'auto'}); if (li.childcontent.hasClass ('right')) li.childcontent.setStyle ('right', 0); if (this.options.slide) { li.childcontent.setStyles ({'left':'auto', 'overflow':'hidden'}); if (li.level0) { if (this.options.direction == 'up') { li.childcontent_inner.setStyle ('bottom', -li._h-20); } else { li.childcontent_inner.setStyle ('margin-top', -li._h-20); } } else { li.childcontent_inner.setStyle ('margin-left', -li._w-20); } } if (this.options.fading) { li.childcontent_inner.setStyle ('opacity', 0); } //Init Fx.Styles for childcontent li.fx = new Fx.Styles(li.childcontent_inner, {duration: this.options.duration, transition: this.options.transition, onComplete: this.itemAnimDone.bind(this, li)}); //effect li.eff_on = {}; li.eff_off = {}; if (this.options.slide) { if (li.level0) { if (this.options.direction == 'up') { li.eff_on ['bottom'] = 0; li.eff_off ['bottom'] = -li._h; } else { li.eff_on ['margin-top'] = 0; li.eff_off ['margin-top'] = -li._h; } } else { li.eff_on['margin-left'] = 0; li.eff_off['margin-left'] = -li._w; } } if (this.options.fading) { li.eff_on['opacity'] = 1; li.eff_off['opacity'] = 0; //li.eff_off['margin-top'] = -li._h; } } if (this.options.action=='click') { if (li.childcontent) { li.addEvent('click', function(e) { var event = new Event (e); if (li.hasClass ('group')) return; if (li.childcontent) { if (li.status == 'open') { if (this.cursorIn (li, event)) { this.itemHide (li); } else { this.itemHideOthers(li); } } else { this.itemShow (li); } } else { if (li.a) location.href = li.a.href; } if(!window.ie) event.stop(); }.bind (this)); //If action is click, click on windows will close all submenus this.windowClickFn = function (e) { this.itemHideOthers(null); }.bind (this); } li.addEvent('mouseenter', function(e) { if (li.hasClass ('group')) return; this.itemOver (li); if(!window.ie) e.stop(); }.bind (this)); li.addEvent('mouseleave', function(e) { if (li.hasClass ('group')) return; this.itemOut (li); if(!window.ie) e.stop(); }.bind (this)); } if (this.options.action == 'mouseover' || this.options.action == 'mouseenter') { li.addEvent('mouseenter', function(e) { if (li.hasClass ('group')) return; $clear (li.timer); this.itemShow (li); if(!window.ie) e.stop(); }.bind (this)); li.addEvent('mouseleave', function(e) { if (li.hasClass ('group')) return; $clear (li.timer); if (li.childcontent) li.timer = setTimeout(this.itemHide.bind(this, [li, e]), this.options.delayHide); else this.itemHide (li, e); if(!window.ie) e.stop(); }.bind (this)); } //when click on a link - close all open childcontent if (li.a && !li.childcontent) { li.a.addEvent ('click',function (e){ this.itemHideOthers (null); //Remove current class this.menu.getElements ('.active').removeClass ('active'); //Add current class var p = li; while (p) { p.addClass ('active'); p.a.addClass ('active'); p = p._parent; } //new Event (e).stop(); }.bind (this)); } },this); if (this.options.slide || this.options.fading) { //hide all content child //this.menu.getElements('.childcontent').setStyle ('display', 'none'); this.menu.getElements('.childcontent').setStyle ('left', -9999); } //tooltips if (this.options.tips) { this.options.tips = this.buildTooltips (); } //Call onLoad if (typeof (this.options.onLoad) == 'function') this.options.onLoad.call (this); }, position: function (li) { //fix position for level0 //show it li.childcontent.setStyle ('left', 'auto'); //reposition if (li.childcontent) { var pos = $merge (li.getPosition(), {'w':li.childcontent.offsetWidth, 'h':li.childcontent.offsetHeight}); var win = {'x': window.getWidth(), 'y': window.getHeight()}; var scroll = {'x': window.getScrollLeft(), 'y': window.getScrollTop()}; if (li.level0) { li.childcontent.setStyle ('margin-left', (pos['x'] + pos['w'] + li._ml > win['x'] + scroll ['x']) ? win['x'] + scroll ['x'] - pos['w'] - pos['x']:li._ml); } else { //sub level if (this.options.direction == 'up') { li.childcontent.setStyle ('bottom', pos['y']+li.offsetHeight-pos['h'] - 20 < scroll ['y']?pos['y']+li.offsetHeight-pos['h'] - scroll ['y'] - 20:0); } else { li.childcontent.setStyle ('margin-top', (pos['y'] + pos['h'] + 20 + li._mt > win['y'] + scroll ['y'])?win['y'] + scroll ['y'] - pos['y'] - pos['h'] - 20 : li._mt); } } } }, getParent: function (li) { var p = li; while ((p=p.getParent())) { if (this.items.contains (p) && !p.hasClass ('group')) return p; if (!p || p == this.menu) return null; } }, cursorIn: function (el, event) { if (!el || !event) return false; var pos = $merge (el.getPosition(), {'w':el.offsetWidth, 'h': el.offsetHeight});; var cursor = {'x': event.page.x, 'y': event.page.y}; if (cursor.x>pos.x && cursor.x<pos.x+el.offsetWidth && cursor.y>pos.y && cursor.y<pos.y+el.offsetHeight) return true; return false; }, isChild: function (child, parent) { return !!parent.getChildren().contains (child); }, itemOver: function (li) { li = (li[0]) ? li[0] : li; if (li.hasClass ('haschild')) li.removeClass ('haschild').addClass ('haschild-over'); li.addClass ('over'); if (li.a) { li.a.addClass ('over'); } }, itemOut: function (li) { if (li.hasClass ('haschild-over')) li.removeClass ('haschild-over').addClass ('haschild'); li.removeClass ('over'); if (li.a) { li.a.removeClass ('over'); } }, itemShow: function (li) { clearTimeout(li.timer); if (li.status == 'open') return; //don't need do anything //Adjust position //Setup the class this.itemOver (li); //Check if this is the first show if (li.childcontent) { var firstshow = true; this.childopen.each (function (li) { if (li.childcontent) firstshow = false; }); if (firstshow && typeof (this.options.onFirstShow) == 'function') { this.options.onFirstShow.call (this, li); } } //push to show queue li.status = 'open'; this.childopen.push (li); //hide other this.itemHideOthers (li); if (li.childcontent) { if (this.options.action=='click' && this.childopen.length && !this.windowClickEventAdded) { //addEvent click for window $(document.body).addEvent ('click', this.windowClickFn); this.windowClickEventAdded = true; } //call event if (typeof (this.options.onItemHide) == 'function') this.options.onItemHide.call (this, li); } if (!$defined(li.fx) || !$defined(li.childcontent)) return; li.childcontent.setStyle ('display', 'block'); this.position (li); li.childcontent.setStyles ({'overflow': 'hidden'}); if (li.childcontent_inner1.ol) li.childcontent_inner1.setStyles ({'overflow': 'hidden'}); li.fx.stop(); li.fx.start (li.eff_on); //disable tooltip for this item this.disableTooltip (li); //if (li._parent) this.itemShow (li._parent); }, itemHide: function (li, e) { li = (li[0]) ? li[0] : li; if (e && e.page) { //if event if (this.cursorIn (li, e) || this.cursorIn (li.childcontent, e)) { return; } //cursor in li var p=li._parent; if (p && !this.cursorIn (p, e) && !this.cursorIn(p.childcontent, e)) { p.fireEvent ('mouseleave', e); //fire mouseleave event } } clearTimeout(li.timer); this.itemOut(li); li.status = 'close'; this.childopen.remove (li); if (li.childcontent) { if (this.options.action=='click' && !this.childopen.length && this.windowClickEventAdded) { //removeEvent click for window $(document.body).removeEvent ('click', this.windowClickFn); this.windowClickEventAdded = false; } //call event if (typeof (this.options.onItemShow) == 'function') this.options.onItemShow.call (this, li); } if (!$defined(li.fx) || !$defined(li.childcontent)) return; if (li.childcontent.getStyle ('opacity') == 0) return; li.childcontent.setStyles ({'overflow': 'hidden'}); if (li.childcontent_inner1.ol) li.childcontent_inner1.setStyles ({'overflow': 'hidden'}); li.fx.stop(); switch (this.options.hidestyle) { case 'fast': li.fx.options.duration = 100; li.fx.start ($merge(li.eff_off,{'opacity':0})); break; case 'fastwhenshow': //when other show if (!e) { //force hide, not because of event => hide fast li.fx.options.duration = 100; li.fx.start ($merge(li.eff_off,{'opacity':0})); } else { //hide as normal li.fx.start (li.eff_off); } break; case 'normal': default: li.fx.start (li.eff_off); break; } //li.fx.start (li.eff_off); }, itemAnimDone: function (li) { //hide done if (li.status == 'close'){ //reset duration and enable opacity if not fading if (this.options.hidestyle.test (/fast/)) { li.fx.options.duration = this.options.duration; if (!this.options.fading) li.childcontent_inner.setStyle ('opacity', 1); } //hide //li.childcontent.setStyles ({'display': 'none'}); li.childcontent.setStyle ('left', -9999); //enable tooltip this.enableTooltip (li); //call event if (typeof (this.options.onItemHideComplete) == 'function') this.options.onItemHideComplete.call (this, li); //Check if there's no child content shown, raise event onLastHide var lasthide = true; this.childopen.each (function (li) { if (li.childcontent) lasthide = false; }); if (lasthide && typeof (this.options.onLastHide) == 'function') this.options.onLastHide.call (this, li); } //show done if (li.status == 'open'){ li.childcontent.setStyles ({'overflow': ''}); if (li.childcontent_inner1.ol) li.childcontent_inner1.setStyles ({'overflow-y': 'auto'}); if (typeof (this.options.onItemShowComplete) == 'function') this.options.onItemShowComplete.call (this, li); } }, itemHideOthers: function (el) { var fakeevent = null if (el && !el.childcontent) fakeevent = {}; var curopen = this.childopen.copy(); curopen.each (function(li) { if (li && typeof (li.status) != 'undefined' && (!el || (li != el && !li.hasChild (el)))) { this.itemHide(li, fakeevent); } },this); }, buildTooltips: function () { this.tooltips = new Tips (this.menu.getElements ('.hasTipThumb'), {'className':'gk-toolbar-thumb', 'fixed':true, offsets:{'x':100, 'y': this.options.direction=='up'?-180:20}, 'direction': this.options.direction}); this.tooltips2 = new Tips (this.menu.getElements ('.hasTipThumb2'), {'className':'gk-toolbar-thumb2', 'fixed':true, offsets:{'x':100, 'y': 20}, 'direction': this.options.direction}); this.tooltips3 = new Tips (this.menu.getElements ('.hasTipThumb3'), {'className':'gk-toolbar-thumb3', 'fixed':true, offsets:{'x':100, 'y': 20}, 'direction': this.options.direction}); return true; }, disableTooltip: function (el) { if (this.options.tips) this.tooltips.disableTip(el); return; }, enableTooltip: function (el) { if (this.options.tips) this.tooltips.enableTip(el); return; } }); jaMegaMenuMoo.implement(new Options);
Time to create page: 0.283 seconds
