Question IP addresses incorrect
16 years 1 month ago #67463 by omzuz
IP addresses incorrect was created by omzuz
Hello!
My site is behind a reverse proxy, just like anyone who has fail safe systems. To Kunena 1.6 Stable the IP of all posts are the same, the LAN address of the reverse-proxy. It looks as if someone has just ignored this common situation, and not written a complete IP address check. In my case it should report X_FORWARDED_FOR address instead the REMOTE_ADDR . This is not any major issue, but nuisance. Yes, I know X_FORWARDED_FOR can be faked, but still it is better than the LAN ip.
I could make the necessary changes to code for myself, but then on the next upgrade I would lose them again. Can you correct this, please? Some ways to do this are listed on thepcspy.com/read/getting_the_real_ip_of_your_users/
16 years 1 month ago #67479 by xillibit
Replied by xillibit on topic IP addresses incorrect
This can be a nice idea, but you define that you are behind a proxy or not by example with a configuration setting into kunena...
16 years 1 month ago #67570 by sozzled
Replied by sozzled on topic IP addresses incorrect
omzuz wrote: Can you correct this, please?
I'm sorry but I don't understand what it is that you want "corrected". Am I right in assuming that you do not want to display IP addresses? Is that what you are asking?
16 years 1 month ago - 16 years 1 month ago #67588 by ChaosHead
Replied by ChaosHead on topic IP addresses incorrect
Apache + nginx? Your hoster should install and enable mod_rpaf.
This is not Kunena problem.
Last edit: 16 years 1 month ago by ChaosHead.
The following user(s) said Thank You: omzuz
16 years 1 month ago #67676 by omzuz
Replied by omzuz on topic IP addresses incorrect
That did it. I was not aware of this module. It solved the problem, and allows me also to install mod_httpbl.
Thank you, ChaosHead!
