Question [Merged topic] Smileys not showing.
15 years 3 days ago - 15 years 3 days ago #96922 by Tryweryn
Hi may be a setting but on www.britmovie.net when i try to post on your latest kunena i dont see the emotcon images like on your forum i just get loads of code as in the attached image.
Any ideas please?
I do have joomsocial 2.2 installed?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : yoo_corona | author: YOOtheme | version: 5.5.1 | creationdate: March 2011
Third-party components: AlphaUserPoints: The file doesn't exist alphauserpoints.xml ! | Jomsocial 2.2.2
Third-party SEF components: sh404sef: The file doesn't exist sh404sef.xml !
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.6.4 | My Kunena Forum Menu 1.6.4
Modules: Kunena Latest 1.6.4
Last edit: 15 years 3 days ago by Tryweryn.
15 years 3 days ago #96923 by Tryweryn
Replied by Tryweryn on topic Re: smileys not showing.
Also only the code is showing in the Emoticon Manager
15 years 3 days ago #96924 by Tryweryn
/public_html/components/com_kunena/template/example/images
Should the be an emoticon file in there?
can i reinstall kunena over the present copy without loosing data?
15 years 3 days ago #96927 by Tryweryn
Tried a reinstall but nothing?
15 years 3 days ago #96933 by sozzled
15 years 3 days ago #96939 by Tryweryn
Solved it was emoticons imported from my vb. deleted all then reinstalled now working a ok thanks!
Time to create page: 0.292 seconds
