Question why am i not able to create any topics under any category?
15 years 5 months ago #93579 by allen012087
I'm not able to create any topics under any category even if i click new topic link it takes to the compose page but if i select a category from the drop down menu nothing is selecting... how can i fix this? thanks friends
15 years 5 months ago #93588 by xillibit
What kunena and joomla versions are-you using ?
15 years 5 months ago #93592 by allen012087
joomla 1.5 and Kunena 1.6.3
15 years 5 months ago #93602 by sozzled
I would like to see the K 1.6 configuration report. Could we see that please?
15 years 5 months ago - 15 years 5 months ago #93625 by allen012087
ya sure.. they are
Legacy mode: Enabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0 | creationdate: 12/26/07
Kunena default template details : Example Template | author: Kunena Team | version: 1.6.3 | creationdate: 2011-01-31
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.2.1) | UddeIm: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Enabled (Version : 1.6.2) | My Kunena Forum Posts: Enabled (Version : 1.6.0-RC1)
Last edit: 15 years 5 months ago by allen012087.
15 years 5 months ago #93644 by xillibit
I advise you to disable legacy mode if you can, do you have a test account on your site ?
Time to create page: 0.254 seconds
