Question Remove login box
15 years 9 months ago #84892 by meqrinda
Remove login box was created by meqrinda
How can I remove the login box?
15 years 9 months ago #84899 by ChaosHead
Replied by ChaosHead on topic Re: Remove login box
Kunena Configuration - Integration - Login and Registration - None
15 years 9 months ago #84901 by meqrinda
Replied by meqrinda on topic Re: Remove login box
Thanks that worked, to edit the text is there an inbuilt function or do i need to find the language file?
15 years 9 months ago #84906 by meqrinda
Found it.
15 years 9 months ago #85035 by meqrinda
Since the 1.6 didnt work with sef, I am using 1.5.9, how do I remove the login box in this version?
15 years 9 months ago #85046 by meqrinda
Solved
Time to create page: 0.160 seconds
