Question Inserting Code (Alternative Language)
14 years 9 months ago #118463 by jnewell
Hey all,
I've searched the forums but have not found a similar topic. I recently got Kunena 1.7.2 installed on my site and LOVE IT. Thank you Kunena team! My question is, my community members typically use C++, C# & VB(.NET) but they don't have those options when inserting code snippets in a post. Can anyone point me in a direction of enabling those languages? I can't find an existing solution but am willing to create one with a little guidance.
Thanks so much!
14 years 9 months ago - 14 years 9 months ago #118465 by sozzled
G'day, Jason, welcome to Kunena and thank you for your question.
As you would be aware, if people allow the unrestricted use of programming code in the forum this opens up the question of securing your website from untrustworthy sources, sources that may not share the desire that you and your community should have to have a forum that works smoothly and reliably. It is possible with the use of the "code" BBcode tag to display source code (that could be written in virtually any language). It is not, however, possible to exercute that code in Kunena.
That is to say, while it would be possible for me to display the following VBscript code
document.write ("Hello World");
it is not possible for me to insert the code and have it execute.
I hope this helps you to understand how Kunena works and what are some of the limitations in how you and your community may be able to use Kunena.
Last edit: 14 years 9 months ago by sozzled.
14 years 9 months ago - 14 years 9 months ago #118466 by jnewell
Thank you for the reply sozzled. I was aware of using the default "code" and I now realize that I was not clear in my goal and for that, I apologize. What I'm looking for really is a way to have the "code" formatted & colorized as you would expect for those languages. Reviewing the rendered html from using the "code" tag, I see:
<pre class="php" style="font-family:monospace;">
which tells me that it's defaulting to php style formatting which is not desired for the languages I listed. Not at all complaining, just looking for a solution.
Thanks again!
Last edit: 14 years 9 months ago by jnewell. Reason: I initially used brackets on the code tag in text.
14 years 9 months ago #118467 by sozzled
I'm not 100% sure how Kunena renders code written for the various options you see in the CODE tool and, I'm sorry to say, that's about the limit of my understanding of the issue. I will ask if one of the Kunena development team can reply to your question directly.
14 years 9 months ago #118468 by jnewell
Thanks again sozzled.
I think that I've figured it out on my own. The solution that I figured out is to download GeSHi and look in the extracted geshi\geshi folder for the desired language.php file. I uploaded one to my server as a test in the plugins/content/geshi/geshi/geshi folder. Refreshed my Kunena editor and the new language automagically showed up and worked as expected.
Hopefully one of the Kunena devs can confirm or deny that this is the correct solution.
14 years 9 months ago #118470 by sozzled
I suspected GeSHi was the place to look, but I didn't want to write that as a definite answer. If it's worked for you, then you have your answer and, again, thank you for your interest in Kunena.
