Question Categories blocked
14 years 11 months ago #112770 by nuno_cruz
Categories blocked was created by nuno_cruz
Absolute beginner here!
I just installed the kunena forum on joomla 1.7 along with the community builder plugin and I'm creating categories but I can't use them when I'm doing a post, I can't assign any moderator to them, I basically can just create them.
14 years 11 months ago #112784 by xillibit
Replied by xillibit on topic Re: Categories blocked
Which exact Kunena version do you have isntalled ? Can-i a screenshot of Kunena categories manager ?
14 years 11 months ago #112860 by nuno_cruz
Replied by nuno_cruz on topic Re: Categories blocked
I'm using kunena 1.7.1
Here is the screen shot
14 years 11 months ago #112862 by xillibit
You need to publish the categories
14 years 11 months ago - 14 years 11 months ago #112864 by nuno_cruz
I wish the problem was that simple, I did that already, as you can see I have one published to test, the thing is that I cant select them whenever this text box appears:
And it isn't just here, it's whenever this drop down list appears, I just can't use it.
Last edit: 14 years 11 months ago by nuno_cruz.
14 years 11 months ago #112876 by nuno_cruz
Another insight, inspecting the elements I detected that they have the propriety disabled set in the html and of course this is the problem. I've edited manually the html in order to remove the disabled property and after this I can select it.
So the question is how do I make this propriety disabled not to be set by default?
