Idea Captcha - How to make it available for Guest posting
J! 1.6.3
SQL Server version: 5.1.47
Is it possible to force Guests to pass Captcha when posting? My Forum is getting too much spam.
I tried to install joomla15captcha ( code.google.com/p/joomla15captcha/ ) and followed the instructions ( docs.kunena.org/index.php/How_to_proper_...aptcha_in_kunena_1.6 ).
However, the right configuration pane where I need to insert kunena.post is absent.
Thank you
CAPTCHA for guest posts was added/improved in K 1.7. You need to upgrade to use CAPTCHA.
J! 1.6.3 is not supported any more. You should be using J! 1.7.3 instead.
I have painfully upgraded both J&K to 1.7.3/1.7.1 but then found out that my host (SourceForge.net) is prohibiting reCaptcha by firewall.
Are you aware of a solution? perhaps a third-party replacement.
Thank you
I can only advise you to read Using CAPTCHA spam protection in Kunena
reCaptcha receives it's images from a Google server. When the user types the verification, reCaptcha checks it against data on the Google server.I know nothing about firewalls interfering in the operation of Kunena CAPTCHA.
This page holds a mixture of 1.5 to 1.7 information. It seems to me that on 1.7 the ONLY Captcha plugin available is reCaptcha. Correct?I can only advise you to read Using CAPTCHA spam protection in Kunena
Do you have asked your host why he blocks google captcha request ?
