Question Some BBCodes doesn't work (bold, italic, ordered list)
14 years 6 months ago #110946 by Tok Tar Bak
there are 3 BBCodes in my Kunena forum they doesn't work. It's bold, italic and the ordered list. The rest works fine. For example underlined or unordered list.
Any ideas?
t.t.b. B)
14 years 6 months ago - 14 years 6 months ago #110956 by sozzled
G'day, Tok Tar Bak, and welcome to Kunena.
Can you show us a picture of how these things do not work properly? I think you've got a Javascript conflict and, my guess, is RokCandy. Does that seem right to you?
14 years 6 months ago #111011 by Tok Tar Bak
I don't use RokCandy and Javascript is activated. Here is a picture:
tnx t.t.b. :dry:
14 years 6 months ago #111020 by sozzled
Very good, and thank you for showing us what you are talking about. The problem is definitely caused by another extension that you've installed on your website. Our difficulty is that we don't know what extensions you have installed on your website but it's probably a template or a plugin used by that template.
You posted your topic in our Support category (even though I don't believe your problem is caused by something that's broken in Kunena). Please read the posting guidelines printed at the top of this page. Someone may have more of an idea about tackling your problem if we could see your configuration report.
Try using a standard Joomla template to see if the problem goes away.
The following user(s) said Thank You: Tok Tar Bak
14 years 6 months ago #111032 by Tok Tar Bak
Thank you very much. My Template is causing the problem.
Amazing! :huh:
14 years 6 months ago - 14 years 6 months ago #111061 by Tok Tar Bak
I was able to reproduce the problem on a local machine, with a new Joomla 1.7 and Kunena 1.7 installation. The described problem only occurs with the template I would like to use.
So nice to know, but how can I find out the root of this effect. What could I try to isolate the conflict.
t.t.b. B)
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : lightbreeze-blue | author: Hurricane Media | version: 1.1 | creationdate: 2011-11-04
Last edit: 14 years 6 months ago by Tok Tar Bak.
Time to create page: 0.268 seconds
