Question problem with the menu tabs
15 years 3 months ago #104814 by tyr
When i go to my forum page i can't get the menu tabs to appear properly. Here is a photo of what it looks like now.
If somebody could help me that would be great.
Thank you
15 years 3 months ago #104821 by Matias
Enable debug and you should see an error message telling what's wrong.
15 years 3 months ago #104822 by tyr
Replied by tyr on topic Re: problem with the menu tabs
Hi, i have just turned on debug mode, and i get this message :
Please check your Joomla menus: Infinite redirect loop detected in /en/forum.html?defaultmenu=136
What do i have to do to fix this?
thank you for your help
15 years 3 months ago #104824 by Matias
You have 2 menu items with the same name/alias. Basically that usually means "forum". By default Kunena adds two menu items named like this: one into Kunena Menu and another into your main menu. In the main menu the item is Menu Alias, which shouldn't conflict with real menu (you can edit it and leave field "alias" empty)..
Did you add your own menu item for Kunena? If you did, change it either to "Entry page" pointing "Forum" in your Kunena menu or make it menu alias just like our default item.
15 years 3 months ago #104827 by tyr
I'm sorry, i didn't particulary understand.
I haven't added an extra kunena menu no
15 years 3 months ago - 15 years 3 months ago #104840 by sozzled
There's a simple solution to this problem.
This question has been asked hundreds of times. It's a frequently-asked question. We have a page of frequently-asked questions with answers! If you click the FAQs tab on the menu near the top of this page you will find your question and answer.
Look at the section "Kunena menu issues" on our FAQs page.
Last edit: 15 years 3 months ago by sozzled.
Time to create page: 0.150 seconds
