- Thank you received: 3
Question Content-plugins in Kunena
- yoonique[.net]
Plugins can be used to many different tasks, including bad words filtering.
What is the ill-effect you're seeing?
- yoonique[.net]
For example the following functions trigger content plugins.
function parseText
function parseBBCode
function stripBBCode
But if you look at the template code, you can see that these functions are used on pretty much every text. So the content plugin is executed in unexpected areas. Problem is that some content plugins (for examples "html tidy") add <p> tags, which don't look good in text fields like like "Last Post".
Those are the only functions where content plugins gets triggered. So for you I would remove the plugin support from parseText and stripBBCode..
- yoonique[.net]
- yoonique[.net]
