Question [Merged topic]HIde/display IP addresses for moderators
15 years 7 months ago - 15 years 7 months ago #91577 by KateKoch44
Is there a way to make it not viewable to anyone? I don't want super admins to see it or anyone below them.
Last edit: 15 years 7 months ago by KateKoch44.
15 years 7 months ago - 15 years 7 months ago #91578 by KateKoch44
Replied by KateKoch44 on topic Re: IP Address
Is this the answer that I need? Thanks for your help.
www.kunena.org/forum/139-support-archive...m-users-ip-addresses
BTW, I couldn't find this through the search forums module, but when I did a google search it popped up. Just FYI.
15 years 7 months ago #91583 by sozzled
Replied by sozzled on topic Re: IP Address
No, that is not the answer you need if you are using K 1.6.
You can hide IP addresses from moderators with the configuration settings:
Forum configuration » Frontend » Look and Feel » Hide IP in messages from moderators = Yes
Although it's not technically true to say this, you cannot hide IP addresses from administrators (including super administrators), this a standard security feature of Kunena (and I would not advise you to change this anyway), you can modify the source code to remove the display.
15 years 7 months ago #91646 by twilliams81
Replied by twilliams81 on topic Re: IP Address
What source code should I modify to remove the IP Address?
15 years 7 months ago #91754 by twilliams81
Does anybody have an idea how to remove this?
15 years 7 months ago #91766 by xillibit
Replied by xillibit on topic Re: IP Address
Look in \components\com_kunena\template\default\view\message.actions.php line 36
