Question Adding custom BBCode
15 years 7 months ago #89496 by DJProfK
Adding custom BBCode was created by DJProfK
Greetings, "first timer" with kunena here, but long phpbb user.
Okkk.. let's get this started.
I'm looking forward into merging from my phpbb3 to kunena, while i already found the documentation for that, i'm also looking forward into adding several custom bbcodes that the community uses on the phpb3 board.
After using search with no luck (did find a couple topics, but the help was none existent, including one with the links which were all broken).
I come here ask for help.
I already know that i need to edit the files myself in order to add the code, since there is no backend option, so i ask:
- Which files i need to edit?
Thank you in advance,
Regards,
- K
15 years 7 months ago #89791 by HolidayAuctionChief
No help here for you yet?
I'm looking to find out how I can change the Fonts/Size/Bold etc in Categories.
Is that the sort of thing you are looking for as well?
15 years 7 months ago - 15 years 7 months ago #89853 by sozzled
Replied by sozzled on topic Re: Adding custom BBCode
HolidayAuctionChief wrote: I'm looking to find out how I can change the Fonts/Size/Bold etc in Categories.
To clarify your question, do want to change the display (size, colour, font-weight) on your site or you want to change the elements/functions in the BBcode toolbar?
I don't have any information about the original question posted in this topic, sorry.
Last edit: 15 years 7 months ago by sozzled.
15 years 7 months ago #89920 by DJProfK
Replied by DJProfK on topic Re: Adding custom BBCode
A bit sad no help so far...
I'm still looking myself at the files, but no luck so far, if i figure it out, i'll post it here, but any help would be much appreciated.
Cheers for both posters,
- K
15 years 7 months ago - 15 years 7 months ago #89967 by supersasho
Replied by supersasho on topic Re: Adding custom BBCode
I'm also a newbie with Kunena and i'm also searching for the files, to be able to put there a new bbcode. I'll hope someone of us will find it and report back. :)
Edit: I searched in lib and found out, it is the kunena.bbcode.js.php located in ../components/com_kunena/lib
Edit2: But this just shows the button on the boardcode. So still searching for the solution.
Edit3: So i found that you also should add some code to ../components/com_kunena/templates/default/smile.class.php
It would be nice to have a tutorial, how to, guide or something.
Last edit: 15 years 7 months ago by supersasho.
15 years 6 months ago #90935 by DJProfK
Well, due to lack of time, i wasn't able to fully give a go a true search into this -_-
But it seems that rokcandy (lets you add your own bbcode to joomla/k2 articles) works flawless (i already had it for my k2 blog, but only noticed yesterday that it was working on the kunena forum too lol XD).
Well, i leave this here since it might help some of you guys too, the only con is that you can't add the buttons, but the code works so far.
Cheers,
-K
