Question Remove Kunena Login and Registration?
16 years 1 month ago #65028 by jeff_j_dunlap
How can I remove the K1.6 fields for login and registration?
Thank you
16 years 1 month ago #65033 by sozzled
Just set Kunena login integration = none
16 years 1 month ago #65040 by weise
where do you find these settings please?
it's not in the Kunena Menu anywhere that Ive seen..
there is a integration section but it does not have this setting their.
16 years 1 month ago #65058 by sozzled
Kunena Forum » Forum Configuration » Integration » Login and Registration = None
The following user(s) said Thank You: jeff_j_dunlap, MindTooth, nur_afini, weise
16 years 4 weeks ago #66436 by ComposerRyan
I want to completely remove the login box that is in the default template of Kunena. The reason is because I already have a login box right above it and it looks very strange having two logins displaying on one page.
Where do I go to remove the login box in 1.6? Thanks for your help!
Ryan
The following user(s) said Thank You: korn
16 years 4 weeks ago #66437 by sozzled
