Question Is it possible to sticky a post within a topic?
14 years 8 months ago #120104 by sozzled
¥ Brutus ¥ wrote: I didn't ask if it's possibile to develop a technical solution, I was asking if it's possible that Kunena orders messages by ID and not by Time!
The short answer is no. Messages are displayed in chronological order of when they were posted. The order can be oldest message first or newest message first. That's what I wrote in msg #4 of this topic.
If you are not asking whether it's possible to develop a technical solution may I ask you whether it's necessary to know where replyid data is stored? The data is probably stored in the database tables kunena_message; I'm not sure and I didn't check before I posted this message.
14 years 8 months ago #120109 by brutus8890
If Kunena uses only a chronological order, can you explain me what kind of order is this?
I want to know more about "replyid" cause I'm looking for the fastest way of reaching my aim (changing the first post) from the database!
14 years 8 months ago #120111 by sozzled
OK, so I obviously made a mistake and I apologise for making a mistake. The picture show the messages sorted in ascending message-id order.
The message ids are, in order, 121885, 121888, 121889.
The message id is assigned when the message is created. This is roughly the same as saying the message id is that same as a chronological "order". This is why I was surprised, when I looked at your picture, to discover that
  • #121885 was created 9½ hours ago
  • #121888 was "created" 12 hours ago ... :huh: (!)
  • #121889 was created 2 hours ago
How did that happen? Did you change something in the database?
14 years 8 months ago #120114 by brutus8890
Yes, i changed the Time of the second post in the database!
So the only way to reorder the posts is to change their ID, right?
14 years 8 months ago - 14 years 7 months ago #120116 by sozzled
Last edit: 14 years 7 months ago by sozzled.
14 years 8 months ago #120131 by CheechDogg
sozzled wrote: With respect to my colleague CheechDogg, his suggestion won't work in your case.
Bummer...I my mind it was possible but never did try it physically...sorry
[img
Find me on Facebook.
