Important [CLOSED] How do to undo Create Menu?
14 years 11 months ago - 14 years 11 months ago #113133 by donkey12
•• Warning: Using direct link to Kunena component. Redirected to menu item in /forum (ItemID=462).
• Please check your Joomla menus: Infinite redirect loop detected in /forums/cosmetics/accessories/post/?id=253&do=delete
• Kunena Menu is missing: You cannot have menu in direct links pointing to Kunena component. You need to create menu item matching to this page.
• You have entered information to an obsolete form from another session. Please verify that the user account is yours and please try again!
• Trying to get property of non-object in components/com_kunena/lib/kunena.login.php on line 24
How do I undo clicking of the Create Menu from Kunena control panel?
Since selecting this option, I can't possibly delete spams from the forum.
When I try, I get the message above.
Last edit: 14 years 11 months ago by donkey12.
14 years 11 months ago - 14 years 11 months ago #113135 by sozzled
How to undo Create Menu? You delete the menu created by the "Create Menu" and build your own; see Customised menus
How to fix up all those problems you've got? You delete all your existing menu items and use the Create Menu feature.
Last edit: 14 years 11 months ago by sozzled.
The following user(s) said Thank You: donkey12
14 years 11 months ago #113626 by richbell77
Hi all,
I was setting up my forum and in the froum configuration field clicked on the 'create menu' icon.
This has now removed some of the tabbed menu from the forum on my site, headings such as 'my topics' etc.
How can I undo this to get it back to how it was?
Really grateful for any help!!
14 years 11 months ago #113631 by sozzled
The following user(s) said Thank You: richbell77
14 years 11 months ago - 14 years 11 months ago #113650 by richbell77
Thanks for that, I think I might be being a bit thick but I cant see from that how to undo the 'create menu'.
I had found this thread when searching before posting my question but couldnt work out from the linked page what to do...
My forum was just about ready to go and I clicked on the create menu link by accident and am worried it's going to be a mess to sort out!
Last edit: 14 years 11 months ago by richbell77.
14 years 11 months ago #113808 by richbell77
Still struggling to sort this out if anyone can help?
