Question How to avoid posts being shown on the homepage
15 years 1 month ago #109102 by redy4it
I use the latest version of Kunena, and the problem is that every post posted in the admin/moderator categories are showing up on the homepage where everyone can read it. How can this be changed so only admins and mods can read it in the forum and not showing on the homepage?
15 years 1 month ago #109135 by Matias
Yes, kind of..
You need to add new top level category (section) and put those private categories under it.
Kunena 2.0 will fix the issue for good.
15 years 1 month ago #109136 by redy4it
When will Kunena 2.0 be available then, so it can be used without those problems? And yes there is a top level category already.
15 years 1 month ago #109143 by Matias
Let me tell how Kunena 1.x works:
Let's assume that you have forum like this:
General
* Subject
** Public
** Moderators
If someone writes a post into moderators category, the last post is also stored to Subject and General. So everyone who has access to those two can see the latest topic from the category page (they cannot enter to the topic, though)..
But there may be configuration issue in your site, too. Check category permissions for your restricted categories and make sure that only users who can access them are allowed to do it. There was a bug in older versions of Kunena that prevented users from seeing categories they had access to, so if your category was set up in "wrong" way, they could have become public.
15 years 1 month ago #109157 by redy4it
It didn't help much as you told me in your answer. The posts are still showing upp on the mainpage on my website.
15 years 1 month ago #109161 by Matias
Maybe someone should look at your site (administration) if everything is OK?
If you want, you can pass (temporary) login/password information inside
