Question Insert Image Buttom doesn't work
16 years 2 months ago #60906 by Masoud
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 24M | Max file upload: 100M
Third-party components: AlphaUserPoints: Enabled (Version : 1.5.10) | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Enabled (Version : 2)
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC2) | Kunena Stats: Enabled (Version : 1.6.0-RC2) | Kunena Login: Enabled (Version : 1.6.0-RC2)
"Add File", "Remove File" and "Insert" Button do same thing in my kunena! all of them open the dialog to choose a file, I've had this problem since the beta 1.6 and it's still present.
and I was wondering if someone show me how can I make thumbnail images bigger.
16 years 2 months ago #60919 by xillibit
What browser do you using ?
Can-you give please a link to your site with a test account (login + password ?
If you can use bbcodes
to let only moderators to see these information.
16 years 2 months ago #60930 by Masoud
Thank you for your replay,
I've tested it in firefox but i just figured out a while ago that in IE i get this error:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; OfficeLiveConnector.1.4; OfficeLivePatch.1.3; .NET4.0C)
Timestamp: Sun, 12 Sep 2010 11:01:48 UTC
Message: 'setStyle(...).getElement(...)' is null or not an object
Line: 1
Char: 4908
Code: 0
URI: /components/com_kunena//template/default/js/editor-min.js
16 years 2 months ago #60971 by sozzled
Thank you, I've seen the the problem (I can reproduce it with Firefox 3.6.9.
Something is wrong with this installation but I don't know what it is. The Insert button (leftmost in the image below) runs the OpenFile dialog; so, too, does the Remove File button (the middle of the three).
The following user(s) said Thank You: Masoud
16 years 2 months ago #61024 by Masoud
I use firefox 3.6.9
yes the middle one is delete buttom, I do not think the problem is related to the installation since all portion of the kunena is working perfectly.
did you see the JS error in IE?
16 years 2 months ago #61314 by Masoud
Time to create page: 0.146 seconds
