Question subscription Checkbox not visible !
16 years 3 months ago #57423 by zomblaa
Hi there
Joomla 1.5.20
Kunena 1.6 RC1
subscription Checkbox not visible in new message!
An idea to fix that?
Thank you
Image:
16 years 3 months ago #57424 by sozzled
What web browser are you using to display that page?
Could you please reply with a copy of your Kunena Configuration Report?
16 years 3 months ago #57426 by zomblaa
Hi
I use Mozilla Firefox 3.6.8
Kunena Configuration Report :
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 72M | Max file upload: 10M
Kunena version detailled: Installed version: 1.6.0-RC1 | Build: 3173 | Version name: Kujadili | Kunena detailled configuration:
16 years 3 months ago #57430 by sozzled
Thank you very much for your reply.
I looked at your website. I notice that the "Powered by Kunena" link has been removed. What other changes have you made to the software?
I think you've changed something. I suggest you might need to reinstall K 1.6 and see if the subscription checkbox is there. What do you think? :unsure:
16 years 3 months ago #57431 by zomblaa
Hi
Thank you for your reply :)
I reinstalled kunena 1.6 RC1 and the problem persists!
Another checkbox is not visible, if I want to select a topic (for to delete or to move) !
16 years 3 months ago #57433 by zomblaa
Hi
The source of the problem is the compatibility with certain joomla templates!
I changed joomla templates and everything is back to normal
Thank you
