Question k1.6B: 'Show help' "No" - configuration not working
16 years 2 months ago #53275 by Admata
On Forum Configuration / Frontend I chose "Show help in Kunena" as "No" and I have no external help link. Help tab is still shown and it takes to Help page that has empty table. Then I added "Help external page link" url and no change in Help tab funtion. Seems like there is a small bug.
My configuration settings are:
Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled | htaccess: Exists | PHP environment: Max execution time: 100 seconds | Max execution memory: 200M | Max file upload: 200M
Kunena version detailled: Installed version: 1.6.0-BETA1 | Build: 3068 | Version name: | Kunena detailled configuration:
16 years 2 months ago #53277 by Baze
In your Joomla Menu, you will see Kunena menu, there you can unpublish the help menu ;)
16 years 2 months ago #53278 by sozzled
Good call and thank you for pointing this out. We're also looking at how we can improve the target of the Help tab for the future. :)
16 years 2 months ago #53302 by fxstein
Admata wrote: On Forum Configuration / Frontend I chose "Show help in Kunena" as "No" and I have no external help link. Help tab is still shown and it takes to Help page that has empty table. Then I added "Help external page link" url and no change in Help tab funtion. Seems like there is a small bug.
This is a left over config setting that we need to remove. This is now controlled by a Joomla menu. Simply go into the Joomla menu manger, look for the kunena menu and disable the help menu link.
That should do the trick.
Hope this helps!
The following user(s) said Thank You: Admata
16 years 2 months ago #53396 by Admata
fxstein wrote: This is now controlled by a Joomla menu. Simply go into the Joomla menu manger, look for the kunena menu and disable the help menu link.
Hope this helps!
Indeed. Joomla menu it is where those nav-tabs are and there they can be modified. That was a way too simple system for me to realise, even I already edited those earlier :silly:
16 years 2 months ago - 16 years 2 months ago #53406 by Cerberus
hmm no replys till i posted :/ very odd
Last edit: 16 years 2 months ago by Cerberus.
