Question Missing buttons on top of forum
15 years 9 months ago - 15 years 9 months ago #52954 by Baze
Hi guys,
i've just migrated to 1.6b, in the migration process at the end there were several "error copy" notes but beneath it it said migration successful and OK to each line. Now everything seems ok, except that i don't see the main buttons (index, recent topics...) is there any option i should use to turn them on?
I'm using j1.5.20 and the v1.6.0-BETA1_b3068_2010-07-19.
Here is link to the forum.
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled | htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 2M
Kunena version detailled: Installed version: 1.6.0-BETA1 | Build: 3068 | Version name: | Kunena detailled configuration:
Last edit: 15 years 9 months ago by Baze.
15 years 9 months ago #52955 by xillibit
Do you have used the function create menu in kunena configuration panel ?
The following user(s) said Thank You: Baze
15 years 9 months ago #52956 by Baze
How did i missed that? :))
Ok now, the menu is created, how can i edit it and where is the translation for the buttons?
I've translated the strings into the language file but the buttons are english..
15 years 9 months ago - 15 years 9 months ago #52958 by Baze
New issue, after generating the menu, the link to the posts dont work. I've tried disabling the sef urls in kunena but it happens the same, when i click to topic i get 404 error :(
SOLVED: The problem was that i didn't assigned link in the main menu to the forum. After adding the forum link in the menu, everything is ok.
15 years 9 months ago #52960 by xillibit
Baze wrote: How did i missed that? :))
In this case re-do a create menu
15 years 9 months ago #52972 by Baze
Tried that three times, buttons remain on english... also can you tell me how can i remove buttons, should i change the template files or there is an option for it?
