Kunena 7.0.7 Released
Solved Im New to Kunena and getting spam everyday. Need Help configuring.
Thank you for mentioning this setting.ratmil wrote: I have noticed a "Stop Forum Spam Configuration" at Kunena settings. I guess it should be worth trying this.
The setting Configuration » Security » Stop Forum Spam Configuration » API Key does not protect Kunena forums from spam. Kunena uses this information (see the file ../components/com_kunena/controllers/user.php) to report the details of a spam account to stopforumspam.com when you ban a user.
I have updated the article I wrote with information about this configuration setting.
Also, regarding online spammers database methods, like stopforumspam, it is true that they may report false positives. This may happen when identifying spammers by IP. You can fix this by using only email addresses to identify. This way it will really hard to mark a real user as spammer.
Thank you very much for changing the article.
About the advertising inserted by R-Antispam, I really thought I had already make it invisible by default. I guess I had the intention and then forgot it. I already changed the extension so this option is disabled by default, so the annoying link at the bottom is only shown if users wants to.
Sorry for posting so much. I guess you will mark me as a spammer, ha ha ha.
I just want to note that you are right about R-Antispam detecting false positives. Yes, the heuristic method may do that.
Anyway, you can disable this option in configuration by unchecking "Integrate with Kunena". And then you can set the Akismet option, of course you will need an Akismet key, you can get it for free at akismet site.
So, this picture would be the preferred configuration of R-Antispam:
thanks for the instruction, just to be sure:
you have set Kunena, handle all input, use plugin to NO.
This sounds like it is turned off? How does this integrate with Kunena technically if the above settings are set to NO?
sharing = caring
R-Antispam integrates with Kunena by default. It checks the text sent by users to the forum and applies a heuristic method to know if it is spam or not. However, as sozzled said this method may detect false positives. So, if you think this is happening to you, you can disable Kunena integration.
But you have to protect somehow, so you can enable Akistmet. This option will trigger spammer detection on user registration, verifying with Akismet online database.
That is the option I am using right now. Although I didn't get much false detection.
