Solved How to migrate from K 1.7 on J! 1.5 to K 3.0 on J! 3.x?
12 years 3 weeks ago #158832 by Johann151
Hello Users,
I have a little problem with a migration from Kunena 1.7.1 to 3.0.6.
(Okay, I should have updatet it a few "years" ago) :-)
Now I run the 3.3.3 Joomla with the 3.0.6 Kunena.
I want to import my old categories and the topics of the old forum.
How can I do it? Just tried to "import" the old database
(from Joomla 1.5.23) but it didn´t work.
I think there are some basic database issues.
Can you give me a tip?
12 years 3 weeks ago #158835 by 810
check your prefix on your database.
The following user(s) said Thank You: Johann151
12 years 3 weeks ago #158843 by Johann151
The Prefix differs.
Old installation: jos
New installation: w3826
I tried to change it manually (in the exported file from the old installation but it didn`t work). How do I change it correctly?
12 years 3 weeks ago #158845 by rich
You have installed already Kunena 3.0.6?
If you use phpMyAdmin then proceed as follows:
1. create a backup of your database
2. deinstall Kunena 3.0.6
3. remove all w3826_kunena tables from your database
4. import all jos_kunena tables in your database
5. mark all jos_kunena tables
6. scroll down and chose in the dropdown menu "Replace table prefix"
7. from
jos_
to
w3826_
8. install Kunena 3.0.6
The following user(s) said Thank You: Johann151, priya, multipass
12 years 3 weeks ago #158847 by Johann151
Thanks @Rich.
It worked!!!!!!
11 years 9 months ago - 11 years 8 months ago #161038 by priya
Thankyou rich its works great :)
Last edit: 11 years 8 months ago by priya.
Time to create page: 0.269 seconds
