Solved "Performing maintenance (cleanup)..." message
12 years 6 months ago #156412 by pads
Can anyone please explain why I am getting the following message -
Message
If I disable the "Kunena - Community Builder Integration " plug-in, the message stops so I am assuming that there is an issue with this section.
If so what is it cleaning, and how can I prevent the message appearing.
Peter
12 years 6 months ago #156415 by sozzled
G'day, pads, and welcome to Kunena.
When and where do you get this message
Message
12 years 6 months ago #156417 by pads
It is there virtually all the time.
Except when I disable the "Kunena - Community Builder Integration " plug-in.
Peter
12 years 6 months ago #156418 by sozzled
Without knowing more about your website it is impossible for us to guess.
I have never seen this message before but, then again, I haven't used Community Builder for a while, either.
12 years 6 months ago #156420 by 810
Please enter here all your components and plugins.
I can't see the string in kunena/CB/joomla, so it is coming from an other extenstion.
12 years 6 months ago #156428 by pads
Regarding the comment "not seen that before.. " If you google for "joomla Performing maintenance (cleanup)", you will get many occurances, and the ones I have looked at all have a Kunena component.
Regarding loaded components-
  • Community Builder #
  • GMapFP
  • JCK Manager *
  • JoomGallery
  • Kunena
  • Mailster
  • Newsfeed
  • Phoca Download *
  • RSEvents #
  • User Article Manager
  • Weblinks *
  • googlelight
  • je-enentcalender *
  • xcloner *
* - loaded after the message started
# - asked and they say not them
Peter
