- Thank you received: 10
Question Backing up website before upgrading and there is error while importing database. Need some help.
Today I wanted to test the upgrade from Kunena 1.7.1 to 1.7.2 and Joomla 1.7.3 to 2.5. Before this I made a backup of my website and database. This is something I did many times before, so I think there is nothing wrong here.
But while trying to re-import my database I got the error:
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '?phpMyAdmin=bb79a8da7b4bc6ce8bd83992983de09e' www.grafischforum.nl/5-overi ' at line 259
Line 259 in my sql file is:
`id` int(11) NOT NULL AUTO_INCREMENT,
Tried this on my local MAMP server as well as on the same webserver as the current forum is running. Both should be able to run this.
I've never seen this error, so guess this is something quite recent. Can someone tell me what I need to do to solve this issue? If I can get this fixed I can go on testing my forum on the new K and J software.
Can someone please help me and solve this issue?
- Jiminimonka
- Elite Member
- YBAS!
On my local system I wanted to import everything, so I can perform and test the upgrade offline. This I've also done a dozen of times before the past couple of years.
Just this time it looks like Kunena or Joomla corrupted something that is now preventing normal behavior. I have no clue about databases, so I need someone that is willing to help me and fix this error.
- Jiminimonka
- Elite Member
- YBAS!
Anyway, I can't help any further. I had absolutely no issue upgrading Joomla to 2.5 or Kunena from 1.7.1 to 1.7.2.
Perhaps you should check that its not an issue caused by J2.5 and some module that needs updating as well.
Before I do the upgrade I want my backup/fallback to be 100%.
- Jiminimonka
- Elite Member
- YBAS!
