Question The Guardian-(xx Forum): Scripting Abuse Detected
I searched the forum but couldn't find solutions to this. Thanks in advance if any one can advise me on the following problem.
I have received a message (see below) saying something about blocking some IP address. But the IP address belongs to one of my users. And since the block the user cannot get on the forum (very slow speed). I checked all CPanel IP denying manager as well as Joomla user manager, and didn't find the user/IP was blocked. Can anyone tell me how I can find out which program blocked the user and then unblock it? Thanks!
Feddie
Scripting Abuse Detected! on Today at 16:58:42
Abusing user ID (Real Name): Guest -> ()
Abuse detected from IP: xxxxxxxxx
Blocked script in Url data: xxxxxxxxx result: ресурс для постинга непригоден (либо отсутствует подключение к интернету)
My Forum, The Guardian
bearplace.net/mycommunity/index.php?opti...=entrypage&Itemid=81
You will see 'Forum' under the user menu. I have restricted posting messages to members only, but it is easy to register your membership.
I am using Kunena 1.6.5. But the Guardian message was sent a few weeks ago when I was still using Fireboard 1.5. After that I upgraded to the current Kunena version but my user still cannot get on the forum.
Thank you very much for help. Let me know if you need further information.
For our security, we do no register ourselves with users' sites. If you need us to login to your site to see the problem it is your responsibility to create a test account for that purpose. You can post the details of that test account here using the "confidential" BBcode tag .fedbear wrote: You will see 'Forum' under the user menu. I have restricted posting messages to members only, but it is easy to register your membership.
I assume, because your last messages posted on this forum related to K 1.0.x and, because you say that your earlier experiences with this "scripting abuse" also related to a previous version of Fireboard (perhaps you meant Kunena) that a lot has changed.
I do not understand how this ""scripting abuse" symptom relates specifically to Kunena. If you use Google you will see that this kind of situation arises from a variety of causes.
Further, I do not know what "Wibi" has to do with Kunena, either. Do you?
Perhaps you are using another forum component with your website and the other product is interfering with Kunena.
I have set up a new account if you would like to test the forum.
I have to apologize my lack of knowledge regarding this security issue. I presume it is some Joomla or maybe forum add-on program that is automatically blocking suspicious use of the forum. But I searched Joomla/Fireboard (I was using it)/Kunena security related topics, and didn't find discussions on that. If you have any idea which direction I should look into, that would be of great help. I am definitely not saying it is a Kunena problem, but thought if it is due to a Fireboard feature, then you might be aware of it.
Kunena is the only forum on my site now. Before it was only Fireboard when the security message was received. I am also using Jomsocial but it wasn't integrated with Fireboard before.
Thanks.
Feddie
Your Kunena menu issues are discussed, in general terms, on the frequently-asked questions page (see the FAQs tab at on the menu tab above).
In order for us to eliminate extraneous, third-party or "customised" software you may be using, please use the default Blue Eagle template.
I could not login to your site using the account you supplied. The error message I received indicated that you have a permissions issue with your directory structure. Please see Securing Kunena . General advice about Joomla preparation in order to operate Kunena is contained in K 1.6 Technical Requirements . I suggest that you study this article carefully.
As I have mentioned, "scripting abuse detected" is not something I have encountered before in connection with Kunena and, for that reason, that is why your topic was moved to this "off-topic" category. What I suggest you do is make sure that you have done everything you can possibly think of in relation to making sure that your Joomla site will support Kunena. it may be helpful, if you have not already done so, to read K 1.6 Upgrade Guide . I realise that you have upgraded from an earlier version of Kunena but, perhaps, you did not consider something else when you did that.
If none of these ideas help, I suggest that you provide us with your K 1.6 configuration report which may indicate something you've overlooked.
Very simply, Fireboard is not compatible with K 1.6. If you were using something designed for Fireboard before, you need to remove those things completely from your website now. Fireboard no longer exists; it is a dead product and has been dead for nearly 3 years. K 1.6 is not Fireboard. Please read K 1.6.5 release notes for other information that may assist.
