Kunena 7.0.8 Released
Question Is there any way to add different images to tabs ?
17 years 1 month ago #22838 by google
Hi, i'm designing a new template. Because my skills are limited I'm wondering if anyone can help me. I want to add for every tab another image, is there any way to do this ? Of course I'm talking about modifying the code.
Thank you.
17 years 1 month ago #22841 by Lintzy
Yes, it is possible. You must give every <li> tag an own ID. I have done it for you (kunena 1.5.3 / template default_ex) i named them tab1, tab2, tab3, see red marked code.
These IDs you can design with CSS.
File fb_layout_php
line 190 - 281
$header .= ' <li id="tab1" ';
if ($func == 'latest' || $func == '') $header .= ' class="Kunena_item_active" ';
$header .=' >'.CKunenaLink::GetShowLatestLink('<span>'.(array_key_exists('showlatest', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . _KUNENA_ALL_DISCUSSIONS . '" title="' . _KUNENA_ALL_DISCUSSIONS . '"/>' : _KUNENA_ALL_DISCUSSIONS).'</span>');
$header .= '</li>';
if ($my_id != 0)
$header .= ' <li id="tab2" ';
if ($func == 'mylatest') $header .= ' class="Kunena_item_active" ';
$header .=' >'.CKunenaLink::GetShowMyLatestLink('<span>'.(array_key_exists('showmylatest', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . _KUNENA_MY_DISCUSSIONS . '" title="' . _KUNENA_MY_DISCUSSIONS . '"/>' : _KUNENA_MY_DISCUSSIONS).'</span>');
$header .= '</li>';
$header .= '<li id="tab3" ';
if ($func == 'listcat' ) $header .= ' class="Kunena_item_active" ';
$header .=' >'.CKunenaLink::GetCategoryListLink('<span>'.(array_key_exists('home', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . _KUNENA_CATEGORIES . '" title="' . _KUNENA_CATEGORIES . '" />' : _KUNENA_CATEGORIES).'</span>');
$header .= '</li>';
if ($my_id != 0)
$header .= ' <li id="tab4" ';
if ($func == 'myprofile' ) $header .= ' class="Kunena_item_active" ';
$header .=' >'.CKunenaLink::GetMyProfileLink($fbConfig, $my_id, '<span>'.(array_key_exists('profile', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . _GEN_MYPROFILE . '" title="' . _GEN_MYPROFILE . '"/>' : _GEN_MYPROFILE).'</span>');
$header .= '</li>';
switch ($type)
case 3:
//Threaded view option removed from Kunena
// if ($view == "flat") {
// $header .= '<li>';
// $header .= CKunenaLink::GetViewLink('view', $id, $catid, 'threaded', '<span>'. _GEN_THREADED_VIEW .'</span>');
// $header .= '</li>';
// else
// $header .= CKunenaLink::GetViewLink('view', $id, $catid, 'flat', '<span>'. _GEN_FLAT_VIEW .'</span>');
break;
case 2:
// $header .= CKunenaLink::GetViewLink('showcat', $id, $catid, 'threaded', '<span>'. _GEN_THREADED_VIEW .'</span>');
// else
// $header .= CKunenaLink::GetViewLink('showcat', $id, $catid, 'flat', '<span>'. _GEN_FLAT_VIEW .'</span>');
if ($is_moderator)
if ($numPending > 0)
$numcolor = '<font color="red">';
$header .= '<li>';
$header .= CKunenaLink::GetPendingMessagesLink( $catid, '<span>'.(array_key_exists('pendingmessages', $fbIcons)
? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . $numPending . ' ' . _SHOWCAT_PENDING . '" />' : $numcolor . '' . $numPending . '</font> ' . _SHOWCAT_PENDING).'</span>');
$header .= '</li>';
break;
case 1:
default:
break;
if ($fbConfig->enablerulespage)
$header .= ' <li id="tab5" ';
if ($func == 'rules' ) $header .= ' class="Kunena_item_active" ';
$header .= ' >'.CKunenaLink::GetRulesLink($fbConfig, '<span>'.(array_key_exists('rules', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . _GEN_RULES . '" title="' . _GEN_RULES . '"/>' : _GEN_RULES).'</span>');
$header .= '</li>';
if ($fbConfig->enablehelppage)
$header .= ' <li id="tab6" ';
if ($func == 'faq' ) $header .= ' class="Kunena_item_active" ';
$header .= ' >'.CKunenaLink::GetHelpLink($fbConfig, '<span>'.(array_key_exists('help', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . _GEN_HELP . '" title="' . _GEN_HELP . '"/>' : _GEN_HELP).'</span>');
$header .= '</li>';
17 years 1 month ago #22847 by google
Hmm, it doesn't work , i must be doing something wrong.
For example I set this id for testing but it doesn't seem to work:
#tab1 {
background:transparent url(images/kunena.logo.png) no-repeat;
I'm sure i'm missing something.
17 years 1 month ago #22849 by Lintzy
you have two possibilities:
li#tab1 {
list-style-image: url(images/kunena.logo.png);
or
li#tab1 {
background: url(images/kunena.logo.png) no-repeat left center;
for "left" (horizontal) and "center" (vertical) you can put px in it, to place it exactly.
17 years 1 month ago - 17 years 1 month ago #22861 by google
I don't know where i'm wrong but it doesn't work. I've attached here kunena.forum.css and fb_layout.php from default_ex template. I only added tab1 to categories in fb_layout.
File Attachment:
File Name: files.zip
File Size:9.08 KB
Last edit: 17 years 1 month ago by google.
17 years 1 month ago - 17 years 1 month ago #22862 by Lintzy
There is no attachment, please give me an url to your forum.
Edit: Ok, now there is the attachement ;) , but could you give me the url to your forum, please? I must look live site.
Last edit: 17 years 1 month ago by Lintzy.
Time to create page: 0.239 seconds
