Question HOW TO: Allow users to delete their own forum posts!
16 years 9 months ago - 16 years 9 months ago #38965 by gxisolutions
View this hack in action on www.noticeboardonline.com or view my blog for support: joomlahax.blogspot.com/
Enjoy!
1: post.php (/components/com_kunena/template/default/)
1.1) Find:
else if ($do == "deletepostnow") { if (!$is_Moderator)
1.2) Change to:
else if ($do == "deletepostnow") { $modified_reason = addslashes(mosGetParam($_POST, "modified_reason", null)); $modified_by = $my->id; $modified_time = CKunenaTools::fbGetInternalTime(); $id = (int) $id; $database->setQuery("SELECT * FROM #__fb_messages LEFT JOIN #__fb_messages_text ON #__fb_messages.id=#__fb_messages_text.mesid WHERE #__fb_messages.id=$id"); $message1 = $database->loadObjectList(); check_dberror("Unable to load messages."); $mes = $message1[0]; $userid = $mes->userid; //Check for a moderator or superadmin if ($is_Moderator) { $allowEdit = 1; } if ($fbConfig->useredit == 1 && $my->id != "") { //Now, if the author==viewer and the viewer is allowed to edit his/her own post the let them edit if ($my->id == $userid) { if(((int)$fbConfig->useredittime)==0) { $allowEdit = 1; } else { $modtime = $mes->modified_time; if(!$modtime) { $modtime = $mes->time; } if(($modtime + ((int)$fbConfig->useredittime) + ((int)$fbConfig->useredittimegrace)) >= CKunenaTools::fbGetInternalTime()) { $allowEdit = 1; } } } } if (!$allowEdit == 1)
1.1.1) Find:
else if ($do == "delete") { if (!$is_Moderator)
1.1.2) Change to:
else if ($do == "delete") { $modified_reason = addslashes(mosGetParam($_POST, "modified_reason", null)); $modified_by = $my->id; $modified_time = CKunenaTools::fbGetInternalTime(); $id = (int) $id; $database->setQuery("SELECT * FROM #__fb_messages LEFT JOIN #__fb_messages_text ON #__fb_messages.id=#__fb_messages_text.mesid WHERE #__fb_messages.id=$id"); $message1 = $database->loadObjectList(); check_dberror("Unable to load messages."); $mes = $message1[0]; $userid = $mes->userid; //Check for a moderator or superadmin if ($is_Moderator) { $allowEdit = 1; } if ($fbConfig->useredit == 1 && $my->id != "") { //Now, if the author==viewer and the viewer is allowed to edit his/her own post the let them edit if ($my->id == $userid) { if(((int)$fbConfig->useredittime)==0) { $allowEdit = 1; } else { $modtime = $mes->modified_time; if(!$modtime) { $modtime = $mes->time; } if(($modtime + ((int)$fbConfig->useredittime) + ((int)$fbConfig->useredittimegrace)) >= CKunenaTools::fbGetInternalTime()) { $allowEdit = 1; } } } } if (!$allowEdit == 1)
2: message.php (/components/com_kunena/template/default_ex/) * NB: default_ex must be the template you are using)
2.1) Find:
if ($msg_edit) { echo " | " . $msg_edit;
2.2) Change to:
if ($msg_edit) { echo " | " . $msg_edit; echo " | " . $msg_delete;
3: view.php (/components/com_kunena/template/default_ex/) * NB: default_ex must be the template you are using)
3.1) Find:
if($allowEdit) { $msg_edit = CKunenaLink::GetTopicPostLink('edit', $catid, $fmessage->id , $fbIcons['edit']?'<img src="' . KUNENA_URLICONSPATH . $fbIcons['edit'] . '" alt="Edit" border="0" title="' . _VIEW_EDIT . '" />':_GEN_EDIT);
3.2) Change to:
if($allowEdit) { $msg_delete = CKunenaLink::GetTopicPostLink('delete', $catid, $fmessage->id , $fbIcons['delete']?'<img src="' . KUNENA_URLICONSPATH . $fbIcons['delete'] . '" alt="Delete" border="0" title="' . _VIEW_DELETE . '" />':_GEN_DELETE); $msg_edit = CKunenaLink::GetTopicPostLink('edit', $catid, $fmessage->id , $fbIcons['edit']?'<img src="' . KUNENA_URLICONSPATH . $fbIcons['edit'] . '" alt="Edit" border="0" title="' . _VIEW_EDIT . '" />':_GEN_EDIT);
Last edit: 16 years 9 months ago by gxisolutions.
Time to create page: 0.099 seconds
