Question Access to a category/forum based on number of posts
17 years 3 weeks ago #32306 by GHA
Hi, I'm looking for a way to make one of my categories only available to people with a minimum of 500 posts.
Is there a way to do this hidden in Kunena? Or does anybody have a suggestion how to make this happen?
I already tried searching both this forum and google but no answer popped up so far. Help is really appreciated :)
16 years 10 months ago #37120 by damsella
I would like to know how to do this as well.
16 years 10 months ago #37123 by etusha
that not possible with k1.5
maybe this features can be add to k1.6
  • C0n
  • C0n's Avatar
  • Offline
  • Premium Member
  • Premium Member
  • Only the strongest will survive
16 years 3 months ago #55547 by C0n
just woundering if theres any hacks or way to modify kunena to a specific number of posts (5 posts) to be able to reply / create a thread in on section of the forum.:ohmy: :silly:
16 years 3 months ago #55562 by sozzled
I remember seeing this question (or one very like it) asked before. I don't remember whether or not a solution was found but I have a feeling that someone did. I'll look for this for you. If someone else finds the answer (or finds where the previous question(s) was/were asked, would they post the information in this topic, please?
  • C0n
  • C0n's Avatar
  • Offline
  • Premium Member
  • Premium Member
16 years 3 months ago #55569 by C0n
well im using a older version of kunena :p since i dont want to update until there are some decent templates out for the 1.6 so this would be helpful il do some searching myself <3
