Important [FIXED] Superadministrator doesn't have to read forum
16 years 2 weeks ago - 16 years 1 week ago #48875 by Leleweb
Hi!
I've a problem with Kunena 1.5.9.
When I created the forum I decided that Superadministrator doesn't have to read the forum. In fact the forum is not mine, I created for an association, and for an honesty question I decided in this way.
I set these permissions: Public Frontend = "Registered" (the forum is Registered Users Only), Public Backend = "Administrator". Childgroups are "No".
Initially all was ok. Then I had to upgrade Kunena at the version 1.5.9..
Yesterday I found the problem: I, a superadministrator, can read the forum (even if I haven't permissions).
I read the scheme in Kunena Docs, all seems to be ok.
Any suggestion?
Thanks in advance!
Last edit: 16 years 1 week ago by Leleweb.
16 years 2 weeks ago #48877 by xillibit
Do you tried with kunena 1.5.11 maybe there are improvements on this point?
What kunena template do you using ?
16 years 2 weeks ago - 16 years 2 weeks ago #48878 by Leleweb
Hi!
Thanks for your answer!
I didn't try kunena 1.5.11... than I try to upgrade.
I use "default_ex" template.
EDIT: I've a bit of fear to upgrade... (I'm going to finish my work...). Do you think an upgrade can fix this situation?
Last edit: 16 years 2 weeks ago by Leleweb.
16 years 2 weeks ago #48887 by Leleweb
xillibit, I've done the upgrade, now Kunena is at 1.5.11 version.
No problem during this, but the previuos problem remains.
How can I do?
Yesterday I've installed NoixACL (I needed it for a group question) but the problem was born not yesterday, but some weeks ago.
16 years 2 weeks ago #48888 by @quila
Childgroups are "No". For Public Frontend or Public Backend?? For Public Frontend should be Childgroups = "No".
16 years 2 weeks ago #48891 by Leleweb
@quila do you speak Italian?
So, that's the exact situation: with NoixACL I created a group ("Consiglio Direttivo"), because I needed a special area for the main members of the association. It works.
This new group depends from "Registered".
Public Frontend = "Registered" (the forum is Registered Users Only);
Childgroup are = YES (because the members of "Consiglio Direttivo" have to watch other forums)
This it the actual situation, but the problem exists before the installation of NoixACL.
Initially the permissions worked and the superadministrator didn't watch the forums where I set up the restrictions.
Sorry for my english!
Time to create page: 0.295 seconds
