Question default_grey template responsible for replies not appearing in preferred chronological sequence
Since the beginning of the use of Kunena Forum the reply message always apeared below the opening/original post.
Since 2 days the first reply shows up on top of the opening/original post and and 2nd reply shows up below the first reply but above the opening/original post.
See the attached image as an example. Check the reply order and also see the ID on the rightside in the red circle.
BTW changing the newest post first and olders post first isn't the solution for this. Also all the users of my forum have this problem.
Thanks in advance !
Best regards, Ralf.
What kunena version do you using ? What kunena template do you using ?
The template is default_grey, can that be ?
Ahh I made a mistake, I'm in the wrong category, can please someone replace me ?
Please use only the default_ex template ( www.kunena.com/forum/138-support/26081-t...-template--defaultex ) and tell me what's happen.
It looks like it's the solution, fantastico !!
