Question Avatar upload problem 1.5.8 and 1.5.9
16 years 9 months ago #39777 by jarasur
in 1.5.8/9 there is a problem, when i tray upload a new avatar or try to using any existing one, it seems success but nothing chahge. it doesnt set new choosed avatar to my profile.
16 years 9 months ago #39781 by sozzled
I will look again at this issue in a few hours from now. In the meantime, you can probably search for information about this. ;)
16 years 9 months ago #39847 by in93r
I think i might have the same problem.
I installed Kunena a few hours ago (Kunena is allready on my other sites)
And I don't see an avatar at all! I can choose from the gallery, but when I confirm, nothing happens. I have also JComments Avatar plugin set to Kunena, and no avatar showing at all...
16 years 9 months ago - 16 years 9 months ago #39852 by sozzled
This could be a known issue. I'm not sure. Have you tried searching for the answer? ;)
Last edit: 16 years 9 months ago by sozzled.
16 years 9 months ago #39855 by xillibit
If i remenber right i have seen, some time ago a thread about with a solution.
Open the components\com_kunena\template\default\plugin\myprofile\myprofile_avatar_upload.php and at line 355 replace this :
$kunena_db->setQuery("UPDATE #__fb_users SET avatar='{{$kunena_db->getEscaped($newAvatar)}' WHERE userid={$kunena_my->id}");
by this :
$kunena_db->setQuery("UPDATE #__fb_users SET avatar='{$kunena_db->getEscaped($newAvatar)}' WHERE userid={$kunena_my->id}");
16 years 9 months ago - 16 years 9 months ago #39920 by eighteffects
I was able to upload an image and the avatar would work. However, if I chose a pre-installed avatar it would not. The above fix worked!
Not sure if it varies but I found the extra '{' on line 335. Thanks for the help, I was pulling my non-existent hair out!
Last edit: 16 years 9 months ago by eighteffects.
Time to create page: 0.145 seconds
