Sticky Fix for RockCandy templates
17 years 1 day ago - 17 years 1 day ago #33667 by Matias
mumins wrote:
Well, there is another Rokcandy workaround:
/plugins/system/rokcandy_system.php find at line ~80
// Do BBCode replacements on the whole page function onAfterRender() {
and after this line paste
// Added to prevent loading on the Forums page, where it conflicted and caused a javascript error. global $option; if ($option == "com_kunena") { return; }
Works fine for me.
Code is the same for rokbox - there find line ~47
$theme = $this->params->get('theme', 'light');
and after it paste the same code.
Original message can be found from here: www.kunena.com/forum/105-solved-or-prior...it=10&start=20#11302
Last edit: 17 years 1 day ago by Matias.
17 years 1 day ago - 17 years 1 day ago #33668 by Matias
Simpler fix can be found from here: www.kunena.com/forum/105-solved-or-prior...it=10&start=10#10298
Creatorffm wrote:
Finaly found the answer! To stop RokCandy from interfering with other components just go to Joomla Admin / Components /RokCandy and disable all of the basic marcos. Here is a list of what needs to be disabled:
[h1]{text}[/h1] - [h2]{text}[/h2] - [h3]{text}[/h3] - [h4]{text}[/h4] - [b]{text}[/b] - [i]{text}[/i] - [code]{text}(/code)
Hope this helps someone! B)
16 years 11 months ago #33896 by tqddn_hmzh
thanx
16 years 11 months ago #34627 by atroa
thanks. worked for me.
16 years 9 months ago #39639 by openpotion
wow thanks! worked great!
16 years 9 months ago #39893 by wicko
I found the line above mentioned line in rokcandy_system.php in line 60
I added the fix and worked fine for me.
