Question SQL Errors On Forum Posting
17 years 1 week ago #32777 by heartuvgold
I'm seeing a whole lot of mysql queries on the forum when I try to make a post.
This is huge so I'm not sure whether it's ok to post it here or not. But here it is.
'); } jQuery(document).ready(function() { jQuery('table.fb-color_table td').click( function() { // var color = jQuery(this).css('background-color'); var color = jQuery(this).attr('id'); bbfontstyle('[color=#' + color + ']', '[/color]'); return false; } ); jQuery('select#fb-bbcode_size').change( function() { var size = jQuery(this).val(); bbfontstyle('[size=' + size + ']', '[/size]'); return false; } ); } ); // From www.massless.org/mozedit/ function mozWrap(txtarea, open, close) { var selLength = txtarea.textLength; var selStart = txtarea.selectionStart; var selEnd = txtarea.selectionEnd; var scrollTop = txtarea.scrollTop; if (selEnd == 1 || selEnd == 2) { selEnd = selLength; } var s1 = (txtarea.value).substring(0,selStart); var s2 = (txtarea.value).substring(selStart, selEnd) var s3 = (txtarea.value).substring(selEnd, selLength); txtarea.value = s1 + open + s2 + close + s3; txtarea.selectionStart = selEnd + open.length + close.length; txtarea.selectionEnd = txtarea.selectionStart; txtarea.focus(); txtarea.scrollTop = scrollTop; return; } // Insert at Claret position. Code from // www.faqts.com/knowledge_base/view.phtml/aid/1052/fid/130 function storeCaret(textEl) { if (textEl.createTextRange) { textEl.caretPos = document.selection.createRange().duplicate(); } } // Insert BBCode in textarea. Code from // www.phpbb.de/ function bbfontstyle(bbopen, bbclose) { theSelection = false; var txtarea = document.postform.message; txtarea.focus(); if ((clientVer >= 4) && is_ie && is_win) { theSelection = document.selection.createRange().text; if (theSelection) { // Add tags around selection document.selection.createRange().text = bbopen + theSelection + bbclose; document.postform.message.focus(); theSelection = ''; if (document.postform.previewspeicher.value == "preview") {fbGetPreview(document.postform.message.value,11);} return; } } else if (document.postform.message.selectionEnd && (document.postform.message.selectionEnd - document.postform.message.selectionStart > 0)) { mozWrap(document.postform.message, bbopen, bbclose); document.postform.message.focus(); theSelection = ''; if (document.postform.previewspeicher.value == "preview") {fbGetPreview(document.postform.message.value,11);} return; } //The new position for the cursor after adding the bbcode var caret_pos = getCaretPosition(txtarea).start; var new_pos = caret_pos + bbopen.length; // Open tag insert_text(bbopen + bbclose); // Center the cursor when we don't have a selection // Gecko and proper browsers if (!isNaN(txtarea.selectionStart)) { txtarea.selectionStart = new_pos; txtarea.selectionEnd = new_pos; } // IE else if (document.selection) { var range = txtarea.createTextRange(); range.move("character", new_pos); range.select(); storeCaret(txtarea); } txtarea.focus(); if (document.postform.previewspeicher.value == "preview") {fbGetPreview(document.postform.message.value,11);} return; } // Insert text at position. Code from // www.phpbb.de/ function insert_text(text, spaces, popup) { var txtarea; if (!popup) { txtarea = document.postform.message; } else { txtarea = opener.document.postform.message; } if (spaces) { text = ' ' + text + ' '; } if (!isNaN(txtarea.selectionStart)) { var sel_start = txtarea.selectionStart; var sel_end = txtarea.selectionEnd; mozWrap(txtarea, text, '') txtarea.selectionStart = sel_start + text.length; txtarea.selectionEnd = sel_end + text.length; } else if (txtarea.createTextRange && txtarea.caretPos) { if (baseHeight != txtarea.caretPos.boundingHeight) { txtarea.focus(); storeCaret(txtarea); } var caret_pos = txtarea.caretPos; caret_pos.text = caret_pos.text.charAt(caret_pos.text.length - 1) == ' ' ? caret_pos.text + text + ' ' : caret_pos.text + text; } else { txtarea.value = txtarea.value + text; } if (!popup) { txtarea.focus(); } } // Caret Position object. Code from // www.phpbb.de/ function caretPosition() { var start = null; var end = null; } // Get the caret position in an textarea. Code from // www.phpbb.de/ function getCaretPosition(txtarea) { var caretPos = new caretPosition(); // simple Gecko/Opera way if(txtarea.selectionStart || txtarea.selectionStart == 0) { caretPos.start = txtarea.selectionStart; caretPos.end = txtarea.selectionEnd; } // dirty and slow IE way else if(document.selection) { // get current selection var range = document.selection.createRange(); // a new selection of the whole txtarea var range_all = document.body.createTextRange(); range_all.moveToElementText(txtarea); // calculate selection start point by moving beginning of range_all to beginning of range var sel_start; for (sel_start = 0; range_all.compareEndPoints('StartToStart', range) maxlimit){ field.value = field.value.substring(0, maxlimit); } else{ countfield.value = maxlimit - field.value.length; } } function submitForm() { submitme=1; formname=document.postform.fb_authorname.value; if ((formname.length0) { // var message = document.postform.message.value; // message = message.replace(/,"<"); // message = message.replace(/>/g,">"); // document.postform.message.value = message; //change the following line to true to submit form return true; }else{ return false; } } function cancelForm() { document.forms.action.value = "cancel"; return true; } //-->
What does this mean?
17 years 1 week ago #32784 by xillibit
This is a javascript error, isn't a mysql error. You have maybe a conflicting plugins installed on joomla! site : docs.kunena.com/index.php/Conflicting_plugins
If it's not the case, can you give me please a link to your site to see the problem .
17 years 1 week ago #32807 by heartuvgold
home-earners.com
thanks for your help.
17 years 1 week ago #32833 by heartuvgold
Have you looked into this yet?
17 years 1 week ago #32876 by xillibit
Your site need registred users, so please give me an user name and a password.
17 years 1 week ago #32914 by heartuvgold
test test123
