Question View counter not counting.NOT SOLVED
17 years 1 month ago - 17 years 1 month ago #31764 by JTM369
I had a thread here:
www.kunena.com/forum/139-solved-or-prior...r-not-counting#28269
I, unfortunately, did not have the internet for quite a while as i moved house so was not able to try your suggestion until now. It still does not work... i did not get any errors for the 2nd suggestion but the view counter still would not count guest page views for posts created by guests.
Have you got any other ideas that may solve the problem?
If you need any info from me, just ask :)
I'm all set up on the internet now so I will keep my eye on this forum ready for a response!.
Last edit: 17 years 1 month ago by JTM369.
17 years 1 month ago #31798 by Matias
One reason may be that you do not have "hold" field in fb_messages table or there are items with value NULL. Can you check if this is true?
17 years 1 month ago #31807 by JTM369
Sorry, I do not know what you mean... can you explain what I need to do?
Thanks again
17 years 1 month ago #31808 by Matias
OK, here are so many users with different skills that I sometimes like to make assumptions. :)
Go to phpMyAdmin or similar tool for MySQL and look at your database. Find jos_fb_messages table and go to see the fields from it.
Actually I wrote wrong above: you should look for moved and if it exists (it should), try to find items where moved=null
SELECT * FROM jos_fb_messages WHERE moved=null
Are there any? If there are, they should be converted to 0:
UPDATE jos_fb_messages SET moved=0 WHERE moved=null
17 years 1 month ago #31812 by JTM369
Don't think i have any set to 'null'.
MySQL returned an empty result set (i.e. zero rows). (Query took 0.0014 sec)
SQL query:
SELECT *
WHERE moved = NULL
LIMIT 0 , 30
Think i done it right?
17 years 1 month ago #31814 by Matias
Yes, it was ok.
What happens when you post a new message?
