Important Wrong name display. HELP!
17 years 1 month ago #30655 by LdyRvnHrt
I have just installed Kunena 1.5 I am running Joomla 1.5 and community builder 1.2
When I log into my Kunena forum... at the top it says "WELCOME" and then the users REAL NAME
This is an issue. Its supposed to be showing their USER NAME not their real one.
Ive checked all the CB and Kunena preferences I can think of, and cant make it change.
PLEASE HELP!!!!
I cant take my site live until this is fixed!!!
17 years 1 month ago #30657 by xillibit
In the kunena configuration panel, you have the possibility to choose if the username if displayed or not. In kunena configuration -> frontend -> user related -> Username.
17 years 1 month ago #30661 by LdyRvnHrt
yes. It says ....
Set to "Yes" if you want the username (as in login) to be used instead of the user's real name
WHich is how I had it set.
So I set it to "No"
And it STILL shows the real name.
Doesnt matter what i set it to, it shows real name at the top
Ive attached an image of what its showing. I set the real name of this admin login to "Wonder Woman" just so I could tell beyond a shadow of a doubt if it was showing real name or username (which in this case... is admin)
Its just not working.
17 years 1 month ago #30677 by xillibit
It's because you use the default template which may have some things which doesn't works well, so i advise you to test with the default_ex template.
17 years 1 month ago - 17 years 1 month ago #30693 by LdyRvnHrt
No good im afraid.
I woke up this morning and the issue had changed. I dont know why. HALF the problem is fixed. Half is not. Could have something to do with the fact that I changed button sets? I dont know.
I tried with the other template you suggested and it doesnt work.
I am currently using the default_grey template with the gainsboro template button set. I like (gainsboro template better but its too light )Ive tried the gainsboro template as well as the one you suggested and no change.
Anyway... Ive attached a pic of the issue as it now stands.
*cry* Helpppppp
Last edit: 17 years 1 month ago by LdyRvnHrt.
17 years 1 month ago #30709 by xillibit
Open the file components/com_kunena/template/default/plugin/profilebox/profilebox.php and at line 118 replace this :
<?php echo _PROFILEBOX_WELCOME; ?>, <b><?php echo $jr_username; ?></b>
by this :
<?php echo _PROFILEBOX_WELCOME; ?>, <b><?php if($fbConfig->username) { echo $jr_username; }else{ echo $kunena_my->username; } ?></b>
