Question Undefined index: txtNumber problem
17 years 2 months ago #28451 by smizmar
I've managed to set up Kunena 1.5.5 just fine and it's working great, except for one small problem.
On the login screen I get this php notice:
Notice: Undefined index: txtNumber in ...\myjoomlainstall\components\com_kunena\template\default\post.php on line 55
Where can I define this index? It's not in the kunena.english.php language file, that one I know.
Since there are references to this index in 3 or 4 other php pages it really needs to be defined somewhere or I will bump into this problem from time to time.
Thx in advance for your help and keep up the good work!
17 years 2 months ago #28655 by xillibit
Do you have enbled the captcha in Kunena configuration ?
17 years 2 months ago #28946 by smizmar
Yes, indeed I do. Is that causing the problem?
17 years 2 months ago #28947 by xillibit
Yes, so try to disable it and check if the problem persists.
17 years 2 months ago #28965 by smizmar
All right, that did the trick. Thanks very much!
This means I can't use the CAPTCHA and anti-spam function? :unsure:
17 years 2 months ago #29003 by xillibit
Yes, you lose the captcha and anti-spam, but you can set your forum for registred user only and use this captcha for login in Joomla! : code.google.com/p/joomla15captcha/downloads/list
