Question Script-1.2.js and other errors
I have few errors..
at first i have the script-1.2.js error...
I have a website with kunena 1.5.3 nativ + Jomsocial + a Rockettemplate + jommcomment + myblog ..
Everything works fine without any errors but with kunena i have few problems... if i want to use kunena with jomsocial support i get the error:
Details zum Fehler auf der Webseite
Benutzer-Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; WOW64; Trident/4.0; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; InfoPath.2; OfficeLiveConnector.1.3; OfficeLivePatch.0.0; .NET CLR 4.0.20506)
Zeitstempel: Fri, 19 Jun 2009 15:52:56 UTC
Meldung: Objekt erwartet
Zeile: 646
Zeichen: 1
Code: 0
URI: www.url.com/components/com_community/assets/script-1.2.js
Zeitstempel: Fri, 19 Jun 2009 15:56:11 UTC
Zeile: 1
Zeichen: 13416
Code: 0
URI: www.cybernetworkxx.eu/components/com_com...s/script-1.2.pack.js
and in the frontend smilies doesnt work .. topic icon doesnt work... dont clickable...
in the backend the menü -> edit smilies... i cant see any smilies ... if i want to fix the pathes ... (edit smilie) there isnt a path .. only a clear url "box"...
maybe someone can help to fix this errors.. if i found more than i will post this...
i have deactivated following plugs..
Rokcandy ....
And i have deactivate the jomsocial - facebook connect modul
now nearly everything works... (I mean js errors)
I can view Categories without any errors.
I can write topics without erros...
i can click Emoticons ...
But now...
If i view Topics / Posts i become this error:
i become this error too if i deactivate ALLLLLL Moduls and ALLLL plugs... and i mean really all moduls and plugs...error details
Zeitstempel: Fri, 19 Jun 2009 20:25:24 UTC
Line: 1
sign: 13416
Code: 0
URI: www.url.com/components/com_community/assets/script-1.2.pack.js
the problem is i use rokcandy for my website articles ...
i have the choice .. if i deactivate rokcandy i must rewrite all articles... or i activate the plugs than i cant use the board...
but now i see something ...
Zeitstempel: Fri, 19 Jun 2009 21:56:19 UTC
Zeile: 1
Zeichen: 11579
Code: 0
URI: www.kunena.com/components/com_community/...s/script-1.2.pack.js
lol just i see something
watch the url!!! same error here... other sign... but same error message
Ok know i thing i have a hint...
If i want watch the board as guest.. no errors... no java errors..
that means it mus be a error with the jomsocial java scripts..
if i am logged in (all plugs and modules deactivated
