Question Reverse Post Order Solution
17 years 4 months ago - 17 years 4 months ago #20785 by DarkSlash
Ok... there's no single way to change ALL users's order in Kunena... how about if we try this until the development team gives us a solution:
1) Create a trigger in mysql wich every time that a row is inserted on the user table, the ordering field is set to 0 instead of 1.
2) Find the file and code where the INSERT of the user is done and modify it by replacing ordering = 1 to ordering = 0.
Anyone can help with this? I use Community Builder and I don't know how it does Kunena to get every new registered user...
EDIT: is one OR another, not both ;)
Last edit: 17 years 4 months ago by DarkSlash.
17 years 4 months ago #20824 by xillibit
do you want change the order in the userlist ? or do you want change the order of posts ?
17 years 4 months ago #20848 by DarkSlash
Order of the posts... like the title of this post says ;)
17 years 4 months ago #20875 by xillibit
There is an parameter nammed default_sort placed in components/com_kunena/lib/config.class.php but when I change this, there is no effect. In the Kunena config panel, there is no way to change this.
The only way to change this is to modified the file components/com_kunena/template/dafault_ex/view.php at line 168 replace:
$ordering = ($fbConfig->default_sort == 'desc' ? 'desc' : 'asc'); // Just to make sure only valid options make it
by this
$ordering ='desc';
17 years 4 months ago #20882 by DarkSlash
Cool! It works! But for getting FPFR (First Posted First Readed) configuracion you have to set ordering to 'asc' instead of 'desc'!
It works perfectly! Thank you, xillibit! You found the solution that many Kunena users where looking for! :)
17 years 4 months ago #20883 by xillibit
You are welcome, I will try do add this possibility in the kunena config panel .
