Before posting new topics in this category K 1.5.x Support: Please read this first.
Question Problem with forum URL
16 years 2 months ago #59563 by iseca
Problem with forum URL was created by iseca
Hello!
I have changed to another host which used Apache, so I have experienced some changes in friendly URLs.
Specifically, old forum URL was www.playstationline.es/ index.php/foro but now it's www.playstationline.es/foro withous "/index.php".
Well, the problem is here; when I go to the current forum URL clicking on item menu "Forum", it shows next page:
Index of /foro
* Parent Directory
* cgi-bin/
However, if I go to Edit the item "forum" and I change Alias from "foro" (forum in spanish) to "foros" or another derivation that won't be exactly "foro", the page is shown correctly.
Thank you very much!
16 years 2 months ago #59570 by Cerberus
Replied by Cerberus on topic Re: Problem with forum URL
.httaccess file check that it is correct
16 years 2 months ago #59575 by iseca
Replied by iseca on topic Re: Problem with forum URL
Hello!
I only renamed htaccess.php to .httaccess
My .httaccess contains:
# @version $Id: htaccess.txt 10492 2008-07-02 06:38:28Z ircmaxell $
# @package Joomla
# @copyright Copyright (C) 2005 - 2008 Open Source Matters. All rights reserved.
# @license www.gnu.org/copyleft/gpl.html GNU/GPL
# Joomla! is Free Software
# READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE
# The line just below this section: 'Options +FollowSymLinks' may cause problems
# with some server configurations. It is required for use of mod_rewrite, but may already
# be set by your server administrator in a way that dissallows changing it in
# your .htaccess file. If using it causes your server to error out, comment it out (add # to
# beginning of line), reload your site in your browser and test your sef url's. If they work,
# it has been set by your server administrator and you do not need it set here.
## Can be commented out if causes errors, see notes above.
# mod_rewrite in use
RewriteEngine On
########## Begin - Rewrite rules to block out some common exploits
## If you experience problems on your site block out the operations listed below
## This attempts to block the most common type of exploit `attempts` to Joomla!
# Block out any script trying to set a mosConfig value through the URL
RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR]
# Block out any script trying to base64_encode crap to send via URL
RewriteCond %{QUERY_STRING} base64_encode.*\(.*\) [OR]
# Block out any script that includes a <script> tag in URL
RewriteCond %{QUERY_STRING} (\<|%3C).*script.*(\>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL
RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL
RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
# Send all blocked request to homepage with 403 Forbidden error!
RewriteRule ^(.*)$ index.php [F,L]
########## End - Rewrite rules to block out some common exploits
# Uncomment following line if your webserver's URL
# is not directly related to physical file paths.
# Update Your Joomla! Directory (just / for root)
# RewriteBase /
########## Begin - Joomla! core SEF Section
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_URI} !^/index.php
RewriteCond %{REQUEST_URI} (/|\.php|\.html|\.htm|\.feed|\.pdf|\.raw|/[^.]*)$ [NC]
RewriteRule (.*) index.php
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
########## End - Joomla! core SEF Section
But I don't know what to do here.
Thank you!
16 years 2 months ago #59577 by Cerberus
follow read carefully bit at top.. im almost certain this is a sef problem and that would be my guess at the prob..
16 years 2 months ago #59580 by iseca
Hi!
I see... I have tried deleting "Options +FollowSymLinks" and putting # at the beggining, and reseted the SEF url but it still doesn't work (maybe I am doing something wrong)
Thanks!
16 years 2 months ago #59722 by iseca
Problem solved!!
I went to root folder in FTP and deleted "Foro" folder.
Thanks!
