Question Will templates for 1.0.10 work with 1.5.3?
Have a question regarding templates compatibility, Will templates for 1.0.10 work with 1.5.3?
TIA
www.kunena.com/forum/111-templates-and-d...plate-designer#15118
I do have automatic upgrade script (written in Python) to make them to work, but I need to clean it up as there are some incremental (conflicting) rules in it.
- Repelzteeltje
- Junior Member
Well, I can say it in here: none of the templates will work in K1.5, don't even brother to try.
If you need a template to test.... I've got one
I am using fireboard like 1.06 or something and have been happy. I have made a second site to demo new modules and I have installed 1.5 kunena to see if i want to upgrade. Now, I understand that my fireboard template wont work but i just downloaded like 15 templates from the forum here and every single one gives an error. Some have two versions - 1.0.10 and unspecified. Neither work. WTF - how is it better to have exactly ZERO options for customization?
I cant use this, i cant convince others ot use it, and i certainly could never get my customers to want this.
I dont understand, so everytime kunena is updated I cant use any templates?
Sorry about your issue but please understand that major version changes ALWAYS require new sets of templates.
It is the very same for Joomla itself. You cannot use a Joomla 1.0 template on a Joomla 1.5 install or vice versa.
Kunena 1.5 stable was just released less than 24h ago. It will take some time for template designers to come out with templates for it. Usually the community is very quick - so I expect to see templates for it within the next few days and weeks. If you like a particular one, I suggest you contact the template designer to see if and when they plan to release a version for 1.5.3
Hope this helps!
fxstein
By using tools like "UltraCompare Professional" from (IDM Computer Solutions). Just load K1.0.10 on one side and K1.5.3 on the other side. it finds the difference in code and allows you to decide what should be changed.
Mahalo,
JBHawaii
Also, I understand what you are saying about joomla templates - however it is more than that with kunena. Otherwise there would only be two types, 1.0.10 and 1.5.3 but it looks like 1.0.10 is a special set all byitself and that older versions require their own templates too. Everyone has 'templates' and '1.0.10 templates'. Now they will have to make 1.5 templates' as well.
But many template-designers modify some php.files too. Every new template is a copy of the template default_ex.
And on this base you will make your new template. If you used the easy solution (only images and CSS-file) and you have installed a new Kunena Version (e.g. new= Kunena 1.5.3), copy Template default_ex from Kunena 1.5.3 a second time, rename it and insert the new images and the changed CSS-File.
But if you changed php.files too in older Kunena Version, for example the message.php, match message.php from the older KN Version with the new KN Version 1.5.3 and insert your changes in message.php from 1.5.3.
My templates (for example) have 40 modified files (nothing what will be done in 5 minutes). I made them for 1.0.9 and 1.0.10, not one of them will work with another Kunena Version without the written way of updating the files.
