Question Category Header color hides text
16 years 4 weeks ago #46163 by bobk
Greetings,
I've added several top level categories, but I can't see them all ... the (background?) color seems to be FFFFFF, and the text is also white, so the name of the category/forum is basically invisible. I've searched the forums for this, discovered Firebug and Colorzilla plugins for Firefox, but it's all beyond me ... how/where do I edit CSS (?) in order to stop this apparently default behavior (see attached screen capture)?
Thanks in advance,
Bob
16 years 4 weeks ago #46171 by @quila
have you meke some change in the kunena.forum.css?
The link to your site will be useful to track error.
16 years 3 weeks ago #46233 by bobk
Hello @quila,
Here's the site: sandbox.villageport.com/tns_j/index.php?...com_kunena&Itemid=21
I did try changing line 31 FFFFFF to something else, but it had no effect (to show the category text) ... don't know php/css/html much, but it seems like the images/cat_title_bg.gif should be showing, just like the other categories above/below it ... basically the same screenshot again, tho with the "hidden" forum highlighted with the cursor to reveal the text:
16 years 3 weeks ago - 16 years 3 weeks ago #46235 by @quila
Hi bobk,
Go to Kunena Configuration -> Forum Administration
Open the Category "Players Forums", then delete the "forums_players" from the field Forum CSS class suffix option, then Save.
Let me know.
Last edit: 16 years 3 weeks ago by @quila.
16 years 3 weeks ago - 16 years 3 weeks ago #46236 by sozzled
G'day, bobk, and welcome to the forum. It's always a good idea to start with the basics: Before you ask for help with template issues ... .
It looks like you've made some kind of customised change to Kunena. :dry: There's some reference to fb_blocktableforums_players that I can't explain. Where did that come from?
Anyway, the solution is fairly easy: you need to add a few lines to the end of your Kunena CSS file (../components/com_kunena/template/default_ex/kunena.forum.css):
table.fb_blocktableforums_players {
background:url("images/cat_title_bg.gif") repeat-x scroll left top #3B3B3B;
Last edit: 16 years 3 weeks ago by sozzled.
16 years 3 weeks ago #46237 by sozzled
Ah, yes, @quila. Of course! That explains the unexplained! Thanks. I learnt something today! :woohoo:
Time to create page: 0.255 seconds
