Question How to change Tabs order
- foxmulder90
I wonder how I can edit the tab-menu order, I would like categories to be to left and then all the other tabs.
PS, I have read about it but it didnt say much and nothing about how you'll do to change it? I know I will have to edit fb_layout.php but thats it
Thanks in advance!
Best regards
Jonathan P
for change tab order just change the place of things between <li></li>, by example for categories link, place their part of code, you can the same thing for the other part of code :
just after that, if you want to see this tab in first :
- foxmulder90
It was just to put the categories-code in first, stupid me
Best regards
Jonathan P
Yes, we've written about this many times. Although the solution is fairly straightforward - well, it's straightforward if you have any understanding of PHP - the solution requires modifying the Kunena source code. Because of this, it would probably be better in future for these kinds of questions to be dealt with in the Hacks, Tips and Tricks category?
These discussion topics explain the principle - they don't necessarily give you the solution; that's for you to develop yourself:
- Tab Menu Edit
- Editing & Reorganizing Menu Items
- Removing Menu Tabs
- Adding a tab?
- Add custom tab buttons
I tried to find some tutorials about tab management in Kunena. I didn't find anything, so I tried to change it directly through Dreamweaver.
Here is the solution :
In my case, I wanted to put Categories Tab in first position.
EDIT : You have to modify the file fb_layout.php (in /components/com_kunena/template/default_ex)
Step 1 : Find this code :
Step 2 : Cut this code.
Step 3 : Paste this code after this :
For other tabs, just follow the same steps.
If you want to delete Catagories tab for example, just delete the first code.
I hope it will help you !
Mickael
- BeTheDance
