Please read
Question Forum Posts being cut off
16 years 7 months ago - 16 years 7 months ago #40148
by kensikora
Forum Posts being cut off was created by kensikora
I have several users who have reported that posts are not 'wrapping' and that they are being 'cut off' on the right.
Here is a screen shot: image missing http://www.kunena.com/media/kunena/attachments/legacy/images/forum-20100216.jpg
I saw some posts about editing a .css file but wasn't sure if this is the same issue!
Last edit: 16 years 7 months ago by kensikora.
16 years 7 months ago #40163
Replied by sozzled on topic Re:Forum Posts being cut off
kensikora: It appears that you are using a customised Kunena template (the user profile box is on the left, not on the right, and the profile box contains customised icons). I have no knowledge of this template.
You originally posted your question in our Support category. Please note: There is only one endorsed and supported Kunena template ... default_ex
image missing http://www.kunena.com/media/kunena/attachments/legacy/images/supportStickies.gif
I have moved this discussion to a different category.
The problem you've described is caused by your Joomla template. If you would like to show us the URL of your website, someone may be able to help you. Alternatively, you might contact the person who provided you with the Kunena template that you are using.
Your Joomla website template is also, probably, responsible for the ragged left column.
16 years 7 months ago #40202
by kensikora
Replied by kensikora on topic Re:Forum Posts being cut off
Thank you for those tips.
The forum is at www.fiberglassics.com/glassic-forums
and yes, it uses a customized template:
The White Pearl v2 Kunena Template by kenlapz.ORG
His site appears to be down at the momement.
I can provide copies of files if any one cares to look at the problem, thank you.
16 years 7 months ago #40204
by kensikora
Well, it isn't the template causing it. I changed it to default_ex and same problem.
Is this a possible fix:
www.kunena.com/forum/136-templates-and-d...it=10&start=10#35846
16 years 7 months ago #40205
I see the problem. :woohoo: The problem is caused by your website template that's not made any allowance for the particular version of Internet Explorer you're using. What version of IE are you using? It looks very old. :ohmy:
This is how your website looks in Firefox. image missing http://www.kunena.com/media/kunena/attachments/legacy/images/attenuatedForumPost.jpg
16 years 7 months ago #40207
by kensikora
Most users aren't having the issue... as far as I can tell it's some using IE 6 or 7.
Time to create page: 0.270 seconds
