Question change forum to work with new domainname on same server
16 years 7 months ago - 16 years 7 months ago #44128 by lastdown
I have a forum running on a server where we don't want users on right now. We have created a few topics on that and now we want to bring it to the live envirionment.
Example.
dev. server: dev.domain.com
live serever: www.domain.com
Before we go to live I wanted to test if everything works. I have created a dns record called test.domain.com that points to the same ip as dev.domain.com
If I then browse to test.domain.com al my links in my forum still keep on pointing to dev.domain.com. However all my joomla article links are fine.
How can i fix this?
Last edit: 16 years 7 months ago by lastdown.
16 years 7 months ago #44129 by Cerberus
Thats because the links for the site are stored in the sql DB to change then you would have to edit the DB and change them :)
***** ALWAYS BACKUP YOUR DATABASE BEFORE MAKING ANY CHANGES TO IT *****
16 years 7 months ago #44132 by lastdown
OW i don't like that at all. Stange that joomla can handle this and kunena not.
anyway is there a script out there that can do this? like replace dev.domain.com by test.domain.com to see if it works as expected.
16 years 7 months ago #44135 by Cerberus
nope and its cause of the user set urls the hardcoded one in kunena do change auto
16 years 7 months ago #44152 by lastdown
it's standard kunena. If you select a picture, click in the img button and submit it will put the complete address in the message. So you can indeed not change the name of your website without all links getting broken.
so export table: jos_fb_messages_text
search and replace dev.domain.com by test.domain.com
empty table: jos_fb_messages_text
import the altered contents back into jos_fb_messages_text
and that should be it.
16 years 7 months ago #44155 by Cerberus
and that wat i said 3 post ago that the db would have to be edited LOLOLOL
