Question SOLVED: Userlist with any users
16 years 9 months ago - 16 years 9 months ago #40850 by Wiesel82
I migrated all my data from simpleboard to kunena.
Everything is imported.
But one problem i couldn't find a solution.
All users will be displayed in the backend and on the userlist it says the right mount of users are registered.
But on the userlist any user will be displayed. Only the mount of sites will be displayed.
What can i do to resolve this issues?
Last edit: 16 years 9 months ago by Wiesel82.
16 years 9 months ago #40852 by xillibit
Replied by xillibit on topic Re:Userlist with any users
the users has been imported ? do you have the users imported in jos_users and jos_fb_users ?
16 years 9 months ago #40853 by Wiesel82
Replied by Wiesel82 on topic Re:Userlist with any users
i have imported the jos_users in jos_users and the other two tables to display the joomla users in the user list in backend.
And i imported the jos_sb_users in jos_fb_users.
16 years 9 months ago #40854 by xillibit
What kunena version do you using ? What kunena template do you using ?
What procedure do you have used to migrate from simpleboard?
16 years 9 months ago #40856 by Wiesel82
I use the lastest version.
I use the standard template of kunena.
I imported the users as csv-File
16 years 9 months ago #40888 by sozzled
Replied by sozzled on topic Re:Userlist with any users
Thank you , Wiesel82, but can you be more specific about the version number of the "latest version" (do you mean K 1.5.9, for example?)and the template name of the "standard template" (do you mean default_ex, for example?) that you are using, please?
I'm sorry, I don't quite understand what you mean by "on the userlist any user will be displayed". Is that a problem? :unsure:
What do you mean by "only the amount (?) of sites will be displayed"? Perhaps you could help with a screenshot of your page, please, to demonstrate the issue.
