Question Avatar issue
16 years 9 months ago #38379 by danmc09
Avatar issue was created by danmc09
I've migrated from one host to another. I backed up my whole site (public html/dbs) and uploaded it to my new host. The only thing thats changed is my domain name.
I've got everything to work on my website perfect apart from avatars not showing up on my forum. I try and select an avatar from the list, it all goes through okay, but the avatar doesn't show up (I just get a blank image in FF and a red cross in IE). I have the enable avatar option in the Kunena config set to yes also.
So I'm stuck really, I'm just wondering if any of you guys have a clue as I sure as hell don't...
Thanks in advance,
Dan
16 years 9 months ago #38380 by sozzled
Replied by sozzled on topic Re:Avatar issue
danmc09 wrote:
I've migrated from one host to another. I backed up my whole site (public html/dbs) and uploaded it to my new host. The only thing that's changed is my domain name.
You've changed at least two things: domain name and webhost. It's possible that you haven't established the right permissions on your directories/files. Read Securing Kunena in the documenation Wiki. Let us know how you get on. :)
16 years 9 months ago #38411 by danmc09
Replied by danmc09 on topic Re:Avatar issue
Hello, I used the Fantastico script to install joomla then I imported my DB. So all the file permissions should be fine. Although I did just check them and all my of my main directories were set to 775
16 years 9 months ago #38414 by xillibit
Replied by xillibit on topic Re:Avatar issue
And what is the permissions on avatar files ?
16 years 9 months ago #38415 by danmc09
com_kunena > file distribution > avatar > gallery - the avatar files are set to 664 (the folder its self is 775)
images > fbfiles > avatar > gallery - the avatar files are set to 664 (the folder its self is 775)
After the migration I noticed that the avatar files wernt working... I then noticed that their was a kunena update, so I updated my forum. It installed some of the old avatar files that come with the update but they don't seem to work either.
16 years 9 months ago #38416 by xillibit
Set the permissions on 777 on all avatars, with this it will good :)
